Televison & Video Logo
Sheila Beela Posted on Jul 06, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
All the sudden I get a no signal message I tried to re scan hhannels I have an amplified tv antenna connected..... what can I do to solve this
Ed Cole
Level 2:
Habit-Forming:
New Friend:
  • Expert 123 Answers
  • Posted on Jul 12, 2019
Ed Cole
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
123
Questions
0
Helped
23784
Points
265
Make sure your TV's input is selected to over the air and not cable,
5 Related Answers
marionbagget
  • 718 Answers
  • Posted on Mar 05, 2009
SOURCE: Toshiba 36
I understand you have;
Toshiba 36" analog tv,
Tivax converter box,
RCA Digital Flat amplified antenna.
You want to get signal over the air;
Connect the antenna to the Tivax converter box.
Connect the Tivax Converter box to the input for the TV.
Turn on the antenna, Converter box and TV. You should get a menu on the tv screen. Follow the instructions and SCAN in the channels in your area by using the converter box remote.
You can see your channels by going to www.tvfool.com and entering your information.
Anonymous
  • 1498 Answers
  • Posted on Dec 27, 2009
SOURCE: I have a dmr ez28
No, you are not obligated to pay for services not rendered or in this case no longer needed.
You will need to contact FixYa administration for the details about canceling the charges. They can be reached at:
[email protected]
There may be continued responses to your posted problem until Monday morning when the offices are once again populated. Bear with them, the experts answering do not initially see what has transpired previous to their posts. When they do see, it's only the comments made by you that are visible.
Normally the responses stop when you accept an answer. In this case, that may complicate things. So, be patient and send them a message explaining the situation.
There will be no problem,
Best regards,
Mike
A
Anonymous
  • Posted on Feb 09, 2010
SOURCE: analog to digital conversion for LCD TV
Bought a conversion box!!
BElectric
DILLIGAF
  • 1140 Answers
  • Posted on Feb 10, 2011
SOURCE: I am having trouble recieving over the air digital
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Anonymous
  • 2992 Answers
  • Posted on Sep 14, 2011
SOURCE: FM antenna is not providing
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Don't understand why local channels no signal it is not storming
Do you have an internal or external antenna? Does you have an signal amplifier, signal splitter or switch connected?
If the TV was previously connected to this antenna and received multiple channels, check the orientation. External antennas can turn under some conditions. With digital (ATSC) signals, this can be a significant issue, as the tuner may not see enough of the signal.
If there was an powered amplifier attached, check if the unit is getting power. Next check if the signal improves when the amplifier, switch or splitter is removed. In my house, usually only a few channels will be initially blocked by a faulty amplifier. In that case, the amplifier turned into a signal filter for a section of the VHF range. Replace the amplifier or switch if it faulty. If you are using a switch, try an amplifier/splitter that will limit the signal attenuation.
Use www.antennaweb.org or www.tvfool.com to check if where the antenna should point. Antennaweb.org assumes an external antenna and gives very conservative channel lists.
If the problem persists, check if another TV tuner works when connected to the antenna. You could connect a tuner box between the TV and the antenna as a solution. Tuners vary in signal strength sensitivity. Alternatively, replace the TV or the input board with the tuner. (If the TV is under warranty, contact the manufacturer. However, for most small TVs (under <32"), the repair costs are not worth the effort. Sites like www.shopjimmy.com can tell you if parts are available - this site specializes in parts from TVs that were damaged in shipping.)
I hope this helps.
My tv says no signal on one channel, how do i get that channel back ?
If you are getting an OTA signal, you should check your antenna, any amplifier or splitter and the station's status. The "No signal" message indicates that the signal is not strong enough to be resolved by the tuner.
1) Is your antenna pointing in the correct direction? Outdoor antennas can sometimes turn in the wind. Reset the antenna to the correct direction.
2) If you have a splitter dividing the signal between TVs or other devices, try a direct connection to the one TV that isn't receiving the channel. Similarly, if you have an amplifier in the system, try using the antenna without it. (I have seen an amplifier become a filter for select channels when damaged.) The only solution is to replace the device or omit it. (In my case, some channels require amplification; thus we replaced the amplifier.)
3) Has the station's local transmitter/repeater been damaged? Check their news feed. Towers fall and transmitter components can fail.
You could try and see if another tuner picks up the signal. Some low end tuners are more sensitive to signal strength. If you are getting the station from another source, check with the provider. We recently lost some of the local PBS stations due to problems with the cable provider's feed. Only one TV is connected to the set top box.
I hope this helps.
ERROR MESSAGE NO SIGNAL INPUT
What is your TV signal source? Press the Input button on the remote and try another input. (Make sure a DVD player or set-top box is on.) If you are on the TV input, try a different channel. Next make sure that your cables are securely connected to the TV and devices. Replace with new cables to test them. If you use an OTA antenna with a splitter, try a direct connection. (Similarly, if you have an amplifier on the signal, try a connection without the amplifier.)
For OTA or direct cable connections, try accessing the Channel Setup menu and rescanning for channels.
I hope this helps.
(I get some weak channels that give No Signal messages when the transmitter has a problem or the weather is bad. I've also had a signal splitter/amplifier fail and block specific channels by becoming a filter. The direct connection identified the amplifier problem.)
3helpful
How do you connect the antenna and get channels to work?
First make sure that your Input is TV. Use the Input button on the remote (to the right of 0) or on the side of the TV (lowest button). To watch OTA channels, after connecting the appropriate antenna for your location with a coaxial cable to your Antenna In port, press Menu then use the arrows to select the Setup submenu. Press Enter to access the submenu and select Installation. Then select Terrestrial and then Input Configuration. Here select Antenna as your input. Press Enter to save. Then scan for channels by returning to the Terrestrial sub menu and select Channel Program to scan all available channels.
Since digital signals are either sufficient for your tuner to interpret or give No Signal, you need to select your antenna and point it with care. Go to anntennaweb.org or tvfool.com to get information on the stations that you should be able to get in your location. Antennaweb assumes an outdoor antenna but still gives a conservative list of available stations. TVfool gives stations depending on the color code of the antenna (indoor, outdoor, amplified) and their directions. If you are sharing the antenna signal with multiple TVs, you may need an amplified splitter. (If you do have an amplifier, you may want to test removing it from the line and directly connecting the 37HL17 to the antenna. When amplifiers get damaged they can turn into signal filters which block the signal completely.)
If you have the correct antenna, check if another TV receives the stations. If so, you may have a bad tuner on the TV. (Some TVs have better tuners than others and pick up the stations even with lower signal strength.)
I hope this helps.
(I use an outdoor antenna and antennaweb indicates that I should only get the stations from 10 miles away. I actually get those from 30 miles away as well. When I set up a neighbor's TVs with indoor antennas, one only gets the stations 10 miles away and the other gets the stations that are 30 miles away. The two antennas couldn't be rotated to the same direction.)
1helpful
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Really? cool... so I have a Panasonic HDTV 720p... just moved, no cable, but I have a TV antenna. Amplified indoor antenna. GE brand model 24700. I powered and connected the coaxial cable between the tv...
You need to go into on screen TV tuner/channel scanning setup page and change the signal source from CABLE to ANTENNA so it will scan again to pick up off the air signals. Please read the TV user manual for more details.
What is the model number of the TV?
Terk od amplified indoor digital antenna installed after install of wintv-hvr 1600 internal hdtv card. win7 opens, followed instructions to scan for atsc digital tv.....NO CHANNELS FOUND. cables...
Unless you are very close to the TV transmitter aerial it is very unlikely that you will get adequate signal for digital TV with an indoor antenna. Check with your neighbours to see what they use and where the nearest transmitter is.
Unfortunately, with indoor an antenna, the amplifier also amplifies any electrical interference from other devices in the building.
First step would be to try taking it outdoors (use an extension cord to get well away from any buildings, trees or large metal objects that could block the signal).
1helpful
LG 42LB5D-UC cannot find channels when scanning
No,Ur Digital antena not getting a good signal,because of lanscape like hills or big buildings,blocking the signal,that why u not getting good signals,or no signals at all.Buy another name brand digital antena with a stronger signal amplifier.Or buy a digital roof antena,well help or solved these problems.
Initial hdmi tv, no signal received
If you are trying to get 'off the air' signals then you must scan for the new digital channels in your reception area (this info should be in your owners manual). If scanning doesn't find any signals, you might have to add a VHF/UHF line amplifier(s) between your antenna and the TV set or improve your outside antenna or the cable leading from it to your set. You might have to resort to subscribing to HD cable or satellite TV.
Toshiba 36" analog TV Tivax converter box RCA Digital Flat Amplified Antenna How do I get signals without cable?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
