Question about Maytag Washing Machines
Does my Maytag Epic have a clean out? - Maytag Washing Machines
Maytag 3000 series washer F21
Just cleaned out the drain inside the Maytag 3000 and boy if that don't fix it nothing will. I think something was growing in there. Seems to be working fine now. Thanks for the help
Feb 03, 2013 | Maytag EPIC MFW9700S Front Load Washer
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
The inside of my maytag epic front loader washing machine smells like mildew. how do i get rid of the smell? its making the clothing smell bad too.
Buy some Affresh cleaner. You can find this at Home Depot. It should clean gookus from front boot. Also, take a dry rag and `clean the boot area of mold and mildew. I know some of my customers just leave the door open overnight to let it air our.
Sep 26, 2010 | Maytag EPIC MFW9700S Front Load Washer
Filter clogged
If this is a Maytag Epic, you are referring to the drain pump reservoir. The following link explains how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Make sure you also check the hose that runs from the bottom of the wash tub to the inlet side of the pump. Small articles of clothing can become lodged here. If you have questions, please post back and let me know. I hope this helps you.
NOTE: If the link does not work for you, copy and paste to your web browser. Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Epic not draining, checked hosees all clear drain pump was checked and it works. Any other suggestions?
i had the same problem a couple months ago---i couldnt figure out why it wasnt draining. It kept saying "F-21"...well i called a "expert" and all it was was the lent trap inside needed cleaning....which isnt in the manual.....it is located in the back---truthfully im not sure where.....you have to remove a bolt and some screws and pull off the back and then clean it......hopefully some of this helped you...
Feb 04, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic frontload dryer won't unlock
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
Dec 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
