Life Fitness 9500RHRT Recumbent Bike Logo
Posted on Aug 22, 2009
Life cycle 5500 has started slipping at levels 4 and up
I have had this lifecycle 5500 for 15 yrs and is used rarely.
While using it now, it has starting slipping .
Can you tell me the parts I need and how to fix it.
thanks
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2286
Points
The display quit working on the 9100 seris
1helpful
2answers
How do I can replace console batteries
Hi Abraham.
What I'm finding in the way of manuals isn't more specific than that the system uses 2 'D' size batteries, which should last about 800 hours. A review here
Lifecycle GX Review Spin Bike Reviews Indoors Fitness (about 2/3 way down the page) mentions that the batteries are in the console and easy to replace. I'd look for a battery door, likely secured with a small phillips head screw, and large enough to accommodate D Cells. It also mentions that there is a low-battery warning at the top of the console.
Hoping this narrows it down for you.
D
Screen wont work no display present
Most likely a dead battery,you could also check and make sure that that the sensor for the flywheel is in tact
You'll have to open up the battery assembly compartment on the user lower left side and replace your old batteries.
The LifeCycle GX power requirements are
• Battery: 2 D-Cell batteries
• Approximate Battery life: 800hrs
If this does not solve your issue or you need further assistance please do not hesitate to contact our Technical Support Team online or by phone 888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
The Fit Test and Fat Burn do not light up as an option on my Lifecycle 6500HR bike, they used to work now they don't.
This really sounds like there is a problem with your console. You might consider contacting LifeFitness for replacement options and or further troubleshooting. 1-800-351-3737 is the contact phone number for them directly.
Chain keeps comming off
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
It sounds like you are dealing with a stretched chain. If the chain will not tension any further, you may be looking at the need to purchase a new chain. Use your model and serial number at the following link to order a new chain.
Bike Parts for LifeFitness LifeCycle 9500 Upright Belts Pedals Seats...
How do I remove the pedals on a 8500 life fitness recumbent bike
Using a wrench, you remove the left pedal as you would loosen a normal, left hand threaded bolt. The right side is a reverse thread and would need to be loosened in the opposite direction.
1helpful
Can't get any power running on my 5500 hr life cycle
You have to start pedaling to get it to start up, some times you have to pedal pretty fast to get it to start up
3answers
Non-slip surface is dirty, discolored
I would try tilex. Be sure to spray it on and let it sit for 15 minutes before you start scrubbing. Use an old fashioned scrub brush on a handle so you can stand and put some leverage into it. If one application doesn't do it, repeat until you have it the way you want it. good luck
Briggs elite 5500 model 01654 putting out too much power at outle
butterfly shaft on engine siezed causing irregular high idle. high idle causes over powering surge from stator/rectifier assy. idle sppeds must be within gen specs for accurate output levels.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
