Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
My Ryobi weed eater loses power at working speed after 5 minutes.
My Ryobi weed eater starts good, runs fine as I work at high speed. However, after it warms up good, it sounds like it is cutting out or on choke or something at high speed. Still runs strong enough to cut weeds, but nothing like it once did.
  • 127 Answers
You need to replace fuel filter inside the fuel tank . fish it out with and empty tank using a coat hanger and a small hood bent on the end.filters are around $9.00
Posted on Aug 22, 2009
SOURCE:
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Have a ryobi ss26 weed whacker and having a problem getting it started.. the instruction manual is missing and after priming the unit, moving it to full and trying to crank it, it will not hit and when it...
Sounds like you need a new spark plug and probably a new gas filter. To start the weed eater it is recommended to pump the primer bulb seven times and the choke full down. You can get the fuel filter out of the tank with a hooked wire. Good luck.
Aug 03, 2017 | Ryobi Gas Hedge Trimmer
Petrol weed eater will not start. Alomost starts
Hi Mark, I own a shop, we will not work on ryobi, have you gotten 2 seasons out of it? If so thats probably as good as it gets. But you can check carb settings. In the USA they come with limiters on the adjustment screws, not too much you can do(break them off) back your adjustments counter clockwise 1half turn.
Dec 20, 2010 | Ryobi Three Trimmer Combo
Ryobi weed eater head won't spin
Sounds like the clutch has taken a long trip south. If the clutch pads are not wore out, try some wd40 on the pad hinges.
Apr 27, 2010 | Ryobi Garden
I have a 31 cc ryobi weed eater start for about
I think a new carburetor kit and a good carburetor tune up is in order my friend. Sounds like it's starving for gas. If it bogs down after warm up when you throttle it, then yes it needs a carb tuning. The L screw is the low side screw and should be turned in lightly until it seats then back it out one and quarter turns (1 1/4). The H screw is your high speed screw. Also, turn it in lightly until it seats, then back it out approximately a 3/4 turn. With these settings the unit should start and may even stay running. Again, if it bogs when throttled, while running turn the L screw out a little more maybe only 1/16th of a turn and then try it again. If it does rev then you'll have to adjust the H screw in about a 1/16th of a turn. But make sure you only do this after the engine has warmed up.
Hope this works, good luck
Skidooer
Sep 27, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Adjustment of the gas air mixture on a Ryobi ss30 weed eater
aside from carb adfustment. remove exhaust screen and scrape off carbon with piece of wood. also repplace the fuel pickup filter in the tank. couple buck at the home depot.
Jun 19, 2009 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Weed eater GTI 17 won't run on high speed
A couple of things may work...
Make sure you have the correct Oil / Fuel mixture, if it is incorrect the motor may have problems running.
Also take off the bottom where the cord is wound up, make sure there hasn't been any grass get wound up inside it, this will cause it to stall out on high RPM.
May 19, 2009 | Poulan Genuine Weedeater Part # 36006-128
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,352 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
lnbn1975
Dennis Tokarzewski
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
