Posted on Aug 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi 50V500 I have a 50" Hitachi 50V500 TV but the "lamp and temp" lights blink, power light is on but no picture or I don't hear a fan running at all when plugged in. Any ideas on problem or approximate cost to repair or should I just replace?
Anonymous
Level 3:
  • Master 630 Answers
  • Posted on Aug 21, 2009
Anonymous
Master
Level 3:
Answers
630
Questions
0
Helped
204818
Points
1976
Sounds like the lamp has gone or the filter needs cleaning.
I just replaced the lamp in my Hitachi 50vf820 tv and it comes on for a second then cuts out and blinks red temp light.
Make sure all the fans are working correctly. If the problem persists then it might be the ballast, the power supply or a bad temp sensor.
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
4helpful
The temp and lamp light start blinking when i turn on the tv and the screen is black and the lamp light stays on hitachi i think it is a 55 inch model # 55vs69a
CK the Lamp Fan to see if it is running ,If you are still running the orignal Lamp then replace it . Mats has them for $99.00
1-800-628-1118
Power light is on, temp light blinks, and lamp light blinks, no picture.
Its possible that your lamp is bad, or you have not closed the lamp cover properly. If you don't close it, the sensor will tell the TV not to turn on.
The tv won't come on it gets power but no picture and on the indicator lights on the control panel only the lamp indicator comes on and just blinks. Did the lamp go out?
The manual says if the lamp light is blinking to check the lamp cover. If it is the temp light that is blinging check that the fans are not locked or shorted.
1helpful
I have a 55 inch Hitachi HDTV it is around 3 years old. as of yesterday it was working fine and today it will not turn on. when i press power button i get a buzzing noise and it sounds like it wants to...
If you hear the Lamp fan turn, it is probably the lamp it self that has failed. If you do not hear the lamp fan turn then the fan could be bad or binding.
Hope this helps,
Skyassoc
5helpful
2answers
No sound no picture
The temp light blinking means that the fan is not running. The lamp light blinking means that the lamp door os not secure. Check to be sure that all access doors are closed properly. There are safety interlocks to prevent the set from powering up if all doors are not properly closed. Did you replace the lamp recently? Re-open the access door and be sure that it is closed completely and straight.
Let me know if you have further problems.
Dan
2helpful
3answers
Need answers
The fan may have went bad. If it's out of warranty you may open it up and try and blow some dust out of the fan to see it that may do the trick if not it may need to be replaced. Westexaudioelectronics.com
Top Hitachi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
old marine
old marine
ZJ Limited
ZJ Limited
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
