Question about Sony Bravia KDL-46V4100 46 in. LCD HDTV
How do i hook external speakers to sony bravia television
  • 3 Answers
The proper way to do this would be to use the audio output from the TV, either analogue left and right or the optical port, and send it into an dedicated amplifier or AV receiver. You can then use the amplifier or receiver to power the external speakers. If you are using a dedicated amplifier with no volume control you will want to change the audio output setting on the TV to "variable out" as oppose to its current "fixed out"settings. You can find this in the TV menu, usually under the audio settings. This will allow you to use the current TV remote to adjust the audio volume coming out of the external speakers.
Posted on Aug 21, 2009
When you connect external speakers on sony bravia ex3/32
Posted on Mar 27, 2011
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Sony Expert
  • 158 Answers
Connections in the back
Posted on Sep 03, 2015
    Master:
  • Sony Master
  • 996 Answers
Use tv audio output pin to connect home theatre,sound amplifier input signal pin & enjoy
Posted on Jan 11, 2015
    New Friend:
  • 54 Answers
I have a set of speakers by JBL called "Creature" - the set has a large woofer and two small satellite speakers. The cord from the back of the central (woofer) unit plugs right into the "headphone" output on the side of my Sony Bravia. All I did was plug it in there as opposed to plugging it into my laptop. That may or may not be the type of speakers you're trying to add but they are easy and give a good sound. I've freed up a lot of floorspace by using these. Also, I don't crank on the volume so that might also make a difference in why you want to add speakers. how do i hook external speakers to sony bravia - hook-external-speakers-sony-bravia-y4jkhvgbf5z5eqrm4ccbeswh-5-1.jpg
Posted on Dec 28, 2014
SOURCE:
How do I get the sound to come through my T.V speakers?
You have to hook from the cable/dish box straight to the audio on the TV. That will get you audio out of the tv.
Dec 09, 2014 | Sony 32" 31.5" Diag Bravia Bx320 Series...
I have a sony bravia KDL-32L4000 LCD TV and the sound has gone
For anything you plug in or just certain things? Before the sound stopped, did you change the sound output to something different? Do you have external speakers plugged in?
If the built-in speakers on the tv are not working, plug the television into a set of external speakers, select the output in the menu accordingly and test them. If they work, might be the speakers are blown or the menu configuration is wrong.
Always check the simplest things first, then work your way up to the harder/more expensive issues.
Rule out speakers, speaker board, connectors, external speakers, components attached to television, etc.
Mar 07, 2013 | Televison & Video
My sound bar hooked up directly to my tv has no sound
You may have to go into the Bravia setup procedure and opt to disable its internal speakers
Nov 17, 2012 | Boston Acoustics TVEEM25 TVee Model 25...
Connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I can't hear my tv speakers
If you are connecting your computer to your TV via the PC cable to look at the internet on your screen - you will also need to hook up an alternate audio cable from your computer to either external speakers or an audio receiver in order to hear sound - a PC cable only carries video from the computer to the television, no audio.
Apr 14, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sound problem
check the menu on the tv to see if the speakers are set to off
I think if you connect it to external amp the tv's speakers must be shut off beofre it will activate the line out audio
Nov 05, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hooking up external speakers to my bravia
You have to conected it to the line out audio. In the back of your tv will be says "Audio Out" conect it with the red and white cable to your rca seround system and press "Aux" button on it.
Sep 17, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Ilo tv
i dont think that the ilo has a sound output port:(
Oct 17, 2007 | iLO V27DMBX Television
Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
14,121 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
