Water is not filling the tray. However water is coming out the dispenser
The water dispenser and the ice maker use a different side for each one. The water control valve is most likely the problem. To test the ice maker fill with tap water and let freeze. If the ice dumps then the water valve is the problem. If you need part numbers I will need your model number. Thank you Sea Breeze
If your model number is the PSW26P then the water control number is WR57X10032 I could not find much on replacement parts ffor the ice maker part number WR30X10093 If you should need additional help feel free to let me know, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
