Hi.
Am trying to fix a friends Dell Inspiron 1525 laptop. The screen is hanging on by just the wires. the hinges having been broken off. When I switch on windows begins to load but the screen becomes distorted with horizontal lines dancing across it, then after a few seconds the screen goes back to normal. This process continues every few seconds. There is a black wire that has broken off on the lefthand side but I cannot see where it should be attached. Could the problem be this wire or could it be the inverter.
Many thanks in advance
Mike
Hello
To fix your laptop follow the steps given below.
And the lines are basically due to the movement of loose connector. So while fixing please fix the connector also.
Thank you
I have already found a new lid on ebay, but before I commit to buying it I need to make sure that the screen problem can be fixed first
