Polaroid FLM-3232 Television Logo
Posted on Dec 03, 2007
HD cable question
I have the FLM 3232 Polaroid TV, and haven't yet been able to get HD to come through on the TV. I have digital cable through Time Warner and have been using a coax connection. When I plug into the 'cable' coax input I get a regular picture without problem. When I switch the connection to the HD coax input, I get 'no picture' when I choose the correct input connector (HD). When I replicate this on my other TVs in the house it works fine, just not the Polaroid. Does anyone have any tips for me on this? Thanks.
  • Anonymous Jan 08, 2008
    I have a UHF antenna connected to a Panasonic PT-44LCX65 and receive HD channels just fine. I also have a Poloroid FLM-3232 that picks up analog fine from the same antenna when the cable is connected to the TV Cable connector. However, when I connect the coax to the HDTV connector I get nothing. Any suggestions?
A
Anonymous
I have the same LCD and my problem was the same as you, you need a powerful antena like a out dor antena or indor antena whit buster
1helpful
2answers
I have an longtime problem with my flm 3232 polaroid hdtv. I have dish network service with the dual receiver. The 3232 is the second tv connected via a coax cable. it work fine on the tv cable input...
Hello, you probably already have gotten this resolved, but I do have some answers to your post. Any cable that you have running from TV1 to the TV2 will nor give you a true HD picture. You could get a CAT5 cable with HDMI ends, but the longer the cable, the less true HD you have. The best resolution to this is to get an additional receiver, or to just stick with the SD picture. If you have any more questions, feel free to e-mail me at [email protected], or you can find us on Twitter!
Becki Barned
DISH Network Customer Service
tip
Polaroid FLM-3232 Service Manual Download
Download Polaroid FLM-3232 LCD HDTV Service Manual
Models: FLM-2632 / FLM-2632M / FLM-2634B / FLM-3232 / FLM-3232M
Models: FLM-323B / FLM-3234B / FLM-3732 / FLM-3732M / FLM-373B
Models: FLM-3734B / FLX-374
Have you misplaced your Polaroid FLM-3232 LCD HDTV Service Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Service Manual?
Follow this link (& click FREE) to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Polaroid FLM-3232 Manual Download
on May 01, 2010 • Televison & Video
tip
Download Polaroid FLM-3232 LCD HDTV Manual
Have you misplaced your Polaroid FLM-3232 LCD HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Polaroid FLM-3232 LCD HDTV Users Guide?
Follow this link
I hope that helps.
_____________________________________________
2helpful
My Polaroid FLM-3232 does not display over air HDTV channels
There is no such thing as a 'digital antenna;' any antenna with sufficient gain and bandwidth will receive whatever signals there are available.
You may have to change the input source via your set's menu so it is looking at the antenna input; it may be set to cable currently.
tip
I hope that helps.
tip
Follow this link
I hope that helps.
FLM3232 will not receive channels directly from Comcast Cable
Use the TV/Cable rf jack and auto program the TV.
Craig
1helpful
Universal remote code for a Polaroid LCD TV
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
HD cable question
It sounds like you dont have the right HD box. When connecting HD you will use an HDMI cable or a component cable consisting of 5 cable total 3 for video two for audio. Coax cable is not used to connect HD to your TV / Monitor.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
