Posted on Aug 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What format do you put movies into for JNC movie mojo
What format do you convert movies to on JNC Movie mojo ssfm2 player
Anonymous
Level 2:
Guru:
  • Expert 519 Answers
  • Posted on Jun 12, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
519
Questions
0
Helped
134631
Points
658
I think it is MP4 or AVI.
so you need an excellent converter to help you with this.
Video Download Studio can help you with this.
it can convert your video to any kind of format,
including AVI, MPEG, MP4, 3GP, WMV, MP3, FLV, MOV, WAV
why not get a free trial from http://www.downloadvideos-convert.com/download-videos-music
hope it can help you more or less!
2helpful
2answers
What format do you put on jnc mojo movie players
According to what I have read you use the MPEG-4 format for video and MP3/ WMA for Audio.
Good Luck,
I hope this helps
Also if you don't have the following formats, you can convert them by using this free format conversion tool that you can download at:
http://www.formatoz.com/
Jnc movie mojo
i did a mistake and knc movie mojo didnt use a loudspeaker again
Mp3 cant format
Try delete everything in the MP3 that isn't .mp3 format, if this doesn't work then you can try to download a program that will format it.
AMV movie dowloads - JNC Movie Mojo ( SSFM-220 )
How to convert wmv, asf, avi, mpg to amv files? iOrgsoft AMV Converter is an easy to use video-to-AMV and AMV-to-video converter application that enables you to extend MP4/MP3/MTV capacity by converting various video files into AMV workable format. AMV Converter has powerful editing capacity that you can customize source video files into different resolution, bitrate, frame rate, etc.
If you have lots of video sources but unable to get them onto your player, AMV converter should be your ideal choice. Please follow the guide below on how to convert AMV video file to or from using the iOrgsoft AMV Converter.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Download RMVB Video Converter free trial spacer.gif How to use video to amv Converter
How do you convert video files into AMV video files that are compatible with your mp3 mp4 player?
Step 1. Download and install iOrgsoft AMV Converter
iOrgsoft AMV converter is a simple-to-use program with intuitive way of operation. You are supposed to download a trial version to evaluate the program by converting video into AMV, we welcome you contact our customer service with your problem.
Step 2. Load video info
Click ADD Files to load video info. You can load as many video files in different formats as you like, the batch mode and powerful code pack within the program can easily take care of every thing.
Step 3 Change defaults setting
After load video files, you can now tweak various values that directly impact on the output result. Hit Option will open a window where you can trim, crop and add effect to the source video. Finally, check the box before Merge Files into One on the bottom of the panel, all the files can be merged into one then.
Step 4 Convert video
Hit Start, the entire list of source video will turn to your delivery format as you preset The time takes vary file and setting you have made..
JNC Movie Mojo failed to work after a mistake
Are you formatting as a fat32 drive? Make sure its not being formatted as ntfs
How do I put video's on to the the media player nextar ma715?
Movie
Press rewind button or fast forward button in main menu to select Movie function and press play button to enter Movie play.
(1) This player supports the playing of movie files in SMV format. Convert the desiredmovie(MPG,AVI,WMV format) to SMV format with transcoder software(video2smv.exe)in the attached CD (if any) or save in the player or downloaded from Internet.
(2) Movie should be put in MVIDEO folder of the player. If there is not such folder,please create one. Please note that the player cannot find those movie files if theyare not put in MVIDEO folder of the player.
Here is the Website for it. It has the PDF manual and the convert software.
http://www.nextar.com/frontend/proddetail.asp?pn=MA715&co=10000309
Hope this helps. M~
1helpful
Compatibility with my MP4 player
Go to jnc website and check their mp4 section (or better yet call JNC) - www.jnc-digital.com; they definitely have mp3 players that rae compat, but you will need to check the manuals for their mp4's to be sure - calling is usually quicker
2helpful
3answers
Jnc Movie MOJO (SSF-H20/H21) is dead
my mojo won't play the vidoe's i load onto it. how do i load it to let it play?
Top JNC Computers Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a JNC Computers Audio Player and Recorder Expert? Answer questions, earn points and help others
