Televison & Video Logo
Anonymous Posted on Jul 06, 2019
Cant play store bought movie dvds on my zv427FX4 dvd recorder
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Apr 01, 2007
SOURCE: portable dvd player will play music cds but not video dvds
Chances are, your DVD player uses one laser to read CDs, and a different laser to read DVDs (since Cds and DVDs are read at different wavelenghts of light). If the DVDs you're trying to watch work properly in other DVD players, it probably means that the DVD laser is dirty, damaged, or burned out. Though you can try cleaning the laser (use Google for suggestions on how to do this, or check the Audiovox website), you will most likely have to get the DVD player repaired, or buy a replacement. Many of the newer CD/DVD players sold today use a single combination laser, which reads both CDs and DVDs, which means that when the laser fails, it will not work at all. Wish I had better news for you, but I guess that the only consolation you have is that your Audivox player still works with CDs...
DENNIS MITCHELL
  • 1003 Answers
  • Posted on Jan 14, 2008
SOURCE: DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Anonymous
  • Posted on Feb 17, 2008
SOURCE: Won't play dvds.
Hi, All. I found this discussion based on a Google search because I was having the same exact problem with playing Superbad on my Philips DVDR3400 after renting the movie 3 times and confirming the DVD played on my computer, etc. The good news is I was able to fix this problem. Go to Philips support at http://www.support.philips.com/support/html/index_us_en.html From that link, enter the model number of your DVD player into Search. Select your player from the list that comes up, and on the next page select "software & drivers" link at the left. This will take you to the firmware upgrade for your exact model which updates the software that runs your DVD player (also, when trying to find your exact model..such as mine was DVDR3400/37...you can find it on the label on the underside of your DVD player or it is on a sticker on the back side of your user manual). This takes you to both the link for the software download as well as detailed instructions on how to do it which are very clear. That includes how to use your remote to check that the version you will upgrade to is newer than the current version on your DVD. This was quite easy so long as you are comfortable with downloading the software to your PC, unzipping and then ripping to a recordable CD disc. You will then put that dics into your DVD which will read the files and upgrade itself. The whole upgrade process on the DVD itself took about 5 minutes. When it was done rebooting after it upgraded, I powered it off/on. Then I played Superbad, laughed and had a good time ;)
Anonymous
  • Posted on Sep 03, 2008
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
Anonymous
  • 315 Answers
  • Posted on Apr 22, 2009
SOURCE: DR 389 DVD player
Try one of these:
1) Press 'setup' on remote control
2) Move down to the 'lock' picture
3) Press '0000000'
4) Select region code as '0'
Or
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
My dvd player keeps saying 'incorrect disk' why? and what can i do to stop it?
I don't understand your problem.
Is it the TV or is it the DVD? You say you tried other dvds and the problem is still there. Looks like the TV is the problem. Sometimes it's hard to help people when they only mention on screen issues. How can first DVD say 'incorrect disk' and then another dvd, and another still say 'incorrect disk'? It just doesn't seem to make sense. Is the contents on the disk a computer recorded movie, film or home movie? If so, you have to record the film on the disk with a format that accept the DVD. Could the DVD be a Blu-Ray, can it play a number of video formats, DVD, DivX, KviD DVD, etc.? Try first with a purchased movie DVD disc, if it doesn't work, then the DVD is faulty. DVD players these days are meant to play a wide range of video format, including CD discs. If you have an old DVD player, you may not play latest discs. But if the DVD is incorporated with the TV, then you have to insert a new movie and see if it plays. Go to an appliance or TV DVD store and talk to them. Or you can purchase a new movie and insert it in. If it doesn't work, you can always return it. As you said, you've tried different DVDs, sounds like it is a separate DVD player. If so, try other movie discs. I get the same warning only when I insert discs with movies I recorded on my computer, such as Pinnacle video editor.
Dvd player does not play store bought dvds only burn ones
Are the DVDs movie DVDs or other software.
If they are movies then you probably have to install a program to view them such as PowerDVD or the free VLC media player.
If the computer cannot play original software DVDs then it could be a problem with your DVD players laser lens and has to be replaced with a new DVD drive or you can buy an external USB one.
Hope this helps.
Zenith XBR411 DVD Recorder/VCR Combo Problem
I have the XBR616 zenith combo.
If your dead set on initializing your dvds, I can try to
do one in my dvd player to see if it works, then send it back to you. I can't guarantee anything, my player is a bit fussy, but I don't mind helping you.
If so, let me know
GO VIDEO VR2940
hello davecad,
is this on all dvds you play even none store dvd's or just the store one,s only ?
this could be a region code or laser miss reading the disc.
riz.
2answers
Won't play dvds.
Model number of the DVD player would really help...\
Bill
3answers
I cant record
I posted this in another person's question but it is probably relevant to you as well. This model (which I own myself) is outdated and needs a firmware upgrade. You might get lucky and get one from their tech support. However, I heard they stopped shipping them nearly a year ago. As it stands your recorder can only use DVD-R that records at 4x (or lower) and DVD-RW that records at 1x. Any other media is useless. Since 4x media is outdated, it may be hard to find at a major retailer. Let me know if you have any luck fixing this or finding working DVDs as I have had the same issue myself. I simply cannot find 4x DVDs in the store.
Why do some DVDs play well and others don't?
just check the data transfer wires.may ur probles sloved
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
