Hold down the "FN" key on your laptop. Look for a key that resembles either a sun or moon with a plus or minus. While holding the FN key, press the minus key until your desired brightness is showing. Let go and that's your fix.
Calculators have two similar signs: the regular minus sign for subtraction, and the negation (change sign) sign. When applied, the latter changes the sign of the quantity to which it is applied. The minus sign - for subtraction is on the central line, the negation sign is smaller and somewhat raised above the center line. The change sign key may be marked (-) , (+/-), or +/-
Minus and change-sign are two completely different things. Minus is used to subtract one number from another. When you press minus when the input line is empty, your telling the calculator to subtract. The only way it can subtract the number you're about to put in is to subtract it from something else, and that something else is the previous answer, hence the "Ans."
If you want to input a negative number, use the change-sign key. If you want to subtract one number from another number, use the minus key.
Try pressing the plus key when the input line is empty. You'll get Ans+ in this case as well, The same with multiply and divide, among others, and for the same reason.
The minus key (-) to the right of the zero key (0) at the top of yuor keyboard, is what you're looking for. If you hold down the Shift key and then press that Minus key you will create an underscore (_).
I really hope this helps, but if it does not, please post your laptop model name so I can better answer your question!
Press and hold the Control key marked with a green diamond, then press the minus key (above the + ) to lighten the screen. If you lighten the screen contrast too much you can darken it as follows: To darken the screen press and hold the diamond key and press the + key.
the solution is already on fixya i just tried it and it works.press the right key and the minus key at the same time release the right key hold the minus key for 10seconds and the L will disappear
Its a little strange. Suppose you want subtract 10 from 38. Do this: Enter 38 press plus key. Enter 10, press minus key. Press the equal sign. You will have the result.
