Televison & Video Logo
Kisakye shilla Posted on Jul 05, 2019
My Ac is reading er.. The remote cnt turn it off or on
1helpful
Which specs has the RAM modul in a Sharp UP 810F ?
the manual should cover that, read it yet?
it is not a computer at all posted to computer repair help. forum
is is Point of Sale terminal, old name Cash Register.
age 2008 , only clue is setting date example, RTM)
so is 14 years old.
not problem stated at all and wants more memory to do what not told, my wild guess is the P O S terminal has amnesia.?
it forgets, and you did not read page 3 in the manual these words
This POS terminal uses a nickel metal hydride battery pack for memory protection.The battery
pack must be replaced at least every three years at the user's expense.
this is RECHARGEABLE battery when fails memory dies.
until replaced. just line on PCs the coin cell dies, same pain
rtm
https://www.manualslib.com/manual/324826/Sharp-Up-820f.html?page=3&term=memory&selected=4#manual
there is no memory upgrades here, but if do, ask the maker for support. and my be super costly that, a new main board.
the list of options from sharp are: this model.
For your UP-800F/810F POS terminal, the following options are available:
For details, contact your authorized SHARP dealer. Do not try to install any options yourself.
1. External printer model TM-T88III/T88IV, TM-U220/230 or TM-U295*
2. Remote customer display model UP-P20DPB
3. Remote drawer model ER-03/05DWB
4. Remote coin case model ER-48CC2, ER-48CC3 or ER-58CC
5. Remote coin case cover model ER-01CV1-5, ER-02CV1-5 or ER-03CV
6. RAM memory board model UP-S04MB2 (says extra)
7. Magnetic card reader model UP-E13MR3
8. EFT interface model UP-I04EF
9. Contactless clerk keys model UP-R10CL2
* The external printer TM series are not SHARP products
there may be 2 choices. now. ask maker SHARP for SUPPORT
UP-S04MB2 / S08MB2 Expansion memory board (4MB / 8MB)
Problem with AC thermostat
You are correct about the "er" message. Best bet is to check your user manual for error codes and then take it from there. If nothing in book it is possible that the answer might be on manufacturer web site.
Could be issue with thermostat itself if the other zone is being cooled properly.
When i switch on my ac its display shows ER nd ac isnt working
ER = ERROR. Need more info or please call a service tech
1helpful
Ac model # 42sd6b er-05 code meaning
Are you trying to run your cooling now? I'm guessing you have a carrier thermostat and that's where this is displaying. It's been awhile since I've came across one but to my vague reculiction that code indicates the outdoor sensor detects low ambient them temperatures which in turn will not allow your air conditioner to run which would make sense this time of year. If you want to run cooling in below 60 degrees temps you must add a "low ambient kit" this shuts the fan down outside to build up higher head pressure without doing this you will just ruin your ac but in your case it won't let you. Google up your Tstats model number and codes if that's not your situation.
Cnt turn sound up with my one for all control on
It may be that the code used to program the one for all remote isn't quite the right one for the freeview box.
Have you tried looking on the one for all website for any new codes for your box?
My remote only turns on an off new fedders wall ac..brand new why
Did the remote come with the AC unit? If not it may have to be reprogrammed to "see" the AC or it may not work at all. If the remote came with the AC dig out that owners manual and read what it says about the remote.
When all else fails, reading the instructions can't hurt.
I have a 1999 Grand Voyager. Whenever it rains, the serpentine belt comes off. What's the problem and solution?
Ok..that is a strange one.. I am going to hazard a guess and suggest you look to the AC compressor.
When you run the defroster the ac compressor comes on..typically whenever the outside temp is above 40 degrees.. the ac compressor kicks in to dry out air inside.
Often when it rains.. the windows fog.. you turn on the defrost.. the ac compressor tries to come on.. and.. there ya go.. rather there your serpentine belt goes.
Several things could cause this.. worn belt.. failing belt tension-er... or failing ac compressor..
If the ac compressor is frozen meaing it will not turn..when the electric clutch on the front engages.. it would cause the pulley to stop turning.. and the belt would have a hard time staying on a non rotating part.
Or if the belt tension-er is bad..or the belt is worn.. when the additional load of the compressor kicks in.. it jumps off.
Finally it could be a combination of all three..
Best of luck..
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
