In many sets, this is an indication of a failed
power supply.
There are at least two supplies in every set;
one is active always so the set can receive commands from the remote and
requires minimal power and rarely fails.
The other is turned on when the set is to be
used and this one, is the likely culprit.
I suggest you contact the service center for
your area and inquire about the cost of board repair or replacement. If the
latter, keep the failed board since there are small shops (I was one before
retirement) with the skills to repair these at a more reasonable cost.
Before
opening the back of your set, pull the plug and allow to sit; preferably
overnight. There
are nasty voltages inside that you want to avoid. The
main power supply is often on a separate board, will have larger-than-average
parts on it, with cylindrical parts (mostly capacitors) and some larger
squarish parts (chokes and transformers) and most likely a 'heat sink,' a
finned aluminum structure with parts attached to it. Look
for a tag with a part number on it and have this available when you start
looking for service or new board. These
assemblies are nearly always only plugged into the rest of the set with clearly
dissimilar plugs so incorrect connections are somewhat prevented. If
you are unsure of yourself, take several pictures of this area before
disconnecting anything that you can then refer to if uncertain. Remember,
many assemblers of most of these just recently came in from small farming
villages in Asia so assembly is kept simple. Good luck-
