Kenmore - 4107# Model Number Information. Kenmore. 4107# Model ... Efficiency. Integrated Modified Energy Factor (IMEF) Field details : 2.92. US Federal ...
... list in Excel. There are currently no Canada only models. ... 4.6 cu.ft High Efficiency Front-Load Washer with PowerFoam&##8482; and Steam. ... 4107**31##;
Save on MBM Destroyit 4107 High Capacity Cross Cut Paper Shredder from ... a large work space, making interaction with this model easy and productive. ... oiler for lubrication of the cutting head makes daily operation smooth and effective.
Save on MBM Destroyit 4107 High Capacity Strip Cut Paper Shredder from ... provide a large work space making interaction with this model easy and productive. ... for lubrication of the cutting head makes daily operation smooth and effective.
PDF
Centralised oiler for effective and convenient lubrication of the shredding head. Powerful three phase motors (4.0 kW for model 4107, 3.0 kW for model 4107 CC) ...
PDF
motors on the market qualified as energy efficient models ... a premium efficiency model with a full-load efficiency ... DOE/GO-102014-4107 • February 2014.
by GA McCoy · 2014 · Cited by 19 · Related articles
Investigate the operation purpose of the Oil Pump. Did you measure the voltage across the terminal or observe that the pump was not operational. It must have an auxiliary function that is not related to main operations. Investigate the purpose of the Oil Pump and deduce what would make it operate then check that switch if their is no voltage measured across the pumps terminal when it should be operating. This deductions may help lead to the problem and a solution.
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
The part number you need is 2601 062 as long as your looking for the gear that meshes with the motor shaft. The price is around 25.00 dollars and phone number for destroyit or as known MBM corp. 800-223-2508
Hope this helps leave feedback if so. If you have trouble getting part contact me i'm a dealer and can get you the part.
