Home Logo
Jackie Pouley Posted on Jul 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I turned my clock chime the wrong way and now my clock will not chime
Dan Apthorp
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 69 Answers
  • Posted on Jan 27, 2020
Dan Apthorp
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
69
Questions
0
Helped
17282
Points
166
Should get it checked by a clock repair person.
1 Related Answer
Anonymous
  • 302 Answers
  • Posted on Nov 13, 2011
SOURCE: need to reset chimes on bielow pendulum clock
Sorry, I am not a clockmaker, I am a watchmaker
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
Clock chimes on the 1/4, but hour chimes just once. When i use the lever on the side, it will chime the proper hour, but when the clock is running only the one time on the hour.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Jan 18, 2017 • Chime Home
How to you set the chimes to the clock with a Landing mantel clock
Aug 21, 2016 • Home
I inherited a Seiko Westminster chime clock. The time is perfect but the hourly chimes are 3 hours behind. How can I synchronize the two?
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
My wm widdop clock chiming out of sequence
Oct 21, 2014 • Home
How to reset a chime clock
Aug 20, 2014 • Home
How to co-ordinate chimes on SWeiko QF141S mantle clock
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
5helpful
3answers
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
Syncronize chime strokes to clock
Top Chime Home Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Chime Home Expert? Answer questions, earn points and help others
