Question about Bushnell Optics
What is error code 07
Bushnell neo ion just finished charging and displays error code 07
2 Suggested Answers
SOURCE:
  • 10543 Answers
SOURCE: How do I do a proper coolant flush on a 07 Saturn ion 2.2 from start to finish?
Get a back flush kit from an auto parts store. You cut the heater hose that does NOT have the water valve in it. The kit has all the parts you need to accomplish it Once installed you connect a garden hose to it, take off the radiator cap and turn on the water. A lot of rust will come out. Now start the engine and turn on the heater to its hottest setting. It will take some time for the engine water to warm up , but the heater core will flush when you do this. After the water clears, put new antifreeze in the radiator , put the cap on the garden hose fitting and you're done. Run the engine until it opens the thermostat and add water if necessary.
Posted on Sep 30, 2015
My bunell neo x doesn't hold the charge for more than 9 holes, what do I do ?
The battery probably needs to be replaced. The manual strongly suggests that a qualified technician replace the battery, so you should probably send it back to Bushnell for repair.
Apr 04, 2018 | The Computers & Internet
Why doesn't it charge?
Three things.
Charger not putting out current.
Battery faulty or disconnected.
Unit faulty.
Aug 24, 2015 | Bushnell Neo Handheld GPS Receiver
Why won't my Bushnell golf watch charge?
After using it for several months it suddenly won't charge. I have tried several times, and I have also tried to clean it with a soft brush. AmanStino Mouse Pad with Gel Wrist Pad black9 0 7 8 AmanStino
Dec 23, 2014 | Bushnell Golf neo GPS Rangefinder Watch
Bushnell neo+ wont charge
Flat batteries. Out of life. Renew.
Oct 04, 2014 | Bushnell Neo Golf Rangefinder GPS
Bushnell parts
go online with Bushnell. Customer service should be able to help you.
Jun 06, 2014 | Bushnell Neo Xs Gps Watches
Can not sync devicebushnell neo+
If you have a PC (Windows) then you MUST use Java V6 as the software interface between your computer and the Igolf site. If you have already switched to Java version 7, it just won't work. Google: neo Java and you'll begin to see the problems. No support from either Bushnell or Igolf on this. I had removed Java (re: all the recent security issues being discussed and installed V7. The application would not launch. I had to remove V7 and go fishing for V6 on the internet and reinstall it. Then I wwas back to it working. There are a number of other issues people are having (two accounts on the same machine... neo and trying to register neo+), Registration expirations, etc. If you can reach the Igolf/Bushnell real technical support people, you will have a better time of getting what you need to work. GEEEEzzzz. Bad, Bushnell! The neo series is great but this iGolf married is playing havoc on your customers!
If you have a MAC, then you need to Google MAC, etc.
Jan 02, 2013 | Bushnell Neo Handheld GPS Receiver
Restore bushnell neo
NEO issued 100 million NEO, or 100 million shares, in the NEO blockchain. NEO works quite a bit like shares. In fact, NEO even gives owners voting rights, which according to its whitepaper, is where the value in the cryptocurrency is derived. Read more at: https://www.neonbeginner.com/2018/04/15/whatisneo/
Apr 29, 2012 | Bushnell Neo Carry Case w/ Belt Clip
Recently received a Bushnell Neo for Christmas and having problems loading Bushnell Neo (provided) software to my computer. I have Windows Vista Home Premium and can't get past Quick Guide step 6,...
I've had the same problem today and found the following advice:
Solution:
1) Click on your Start Menu
2) Select Computer
3) Open Local Disk C.
4) Open Program Files
5) Open Bushnell
6) Open Neo Sync
7) Open Native
8) Delete IGolf.lck
9) Close out of everything, restart your PC, and attempt to launch the Sync Application again when your computer has started back up.
If the above fails to solve the problem, you need to install a new USB driver. Contact iGolf at 858-300-5513 858-300-5513 and they will email you the PL2303 Prolific Driver.
I downloaded the driver from
http://www.prolific.com.tw/eng/downloads.asp?ID=31
rather than send an email and now have it working on XP, Vista and windows 7 starter.
G.
Jan 09, 2010 | Bushnell GPS
Downloaded the sync app to my pc but it won't install.
This seems to be a problem on PCs using Windows 7.
Solution:
2) Select Computer
5) Open Bushnell
6) Open Neo Sync
7) Open Native
8) Delete IGolf.lck
If the above fails to solve the problem, you need to install a new USB driver. Contact iGolf at 858-300-5513 and they will email you the PL2303 Prolific Driver.
Dec 28, 2009 | Bushnell Neo Handheld GPS Receiver
Optics Logo
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Ekse
Goldi Kunal
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
