This appears to be a Walmart, Amazon, eBay special without a maker website which usually means made in China and sold in bulk. There is limited help here and some videos. Motor and Capacitor wiring all works to the same diagram.
There are no official wiring diagrams because there is supposed to be no home repair. That capacitor has about 120,00 volts at 10 amps just waiting for you to get within an inch of it. It is heart stopping power. There are some general diagrams here.
3 wires for compressor, 3 for fan. 2 comp. wires go to the top of the contactor, the remaining goes to herm terminal on capacitor. 1 fan wire goes to the top LEFT of contactor, remaining 2 go to com and fan on capacitor. You will then have 1 wire left that goes to the com on the capacitor and should go back to the top RIGHT of the contactor. NOTE: IF YOUR FAN MOTOR IS RUNNING BACKWARDS (MEANING AIR IS NOT BLOWING OUT OR UP) swap the to fan motor wires on the capacitor (fan and com) this should reverse rotation. ALWAYS REMEMBER TO TURN POWER OFF AND DISCHARGE CAPACITOR BEFORE TOUCHING WITH INSULATED SCREWDRIVER. Good Luck!
Why are you replaceing capacitors? If they are "shot" put new back just the way the old were. Mark wires before you remove old. If capacitors are missing I understand the problem. Since you didn't indicate a model, you may find a service manual with wiring diagram here:
http://www.manualslib.com/
I would think you have solvrd this by now but anyway I needed your model number of the unit outside more than the capacitor. Here is a simple diagram.so try to go by location and your colors. Should you have questions I will be here, Thanks Sea Breeze More Carrier AC Wiring Diagrams
Hi my name is Luke and I bought a Ingersoll-Rand 7.5 compressor and won’t start. I noticed it has a wire not connected on the capacitors it’s a blue wire that reads t5 v3 there’s a capacitor with open prong before two start caps and another capacitor after the two start caps , at least that’s what it reads on caps unless they have been wired wrong , being that I would think the start up caps should be wired first from powers supply box , want to know where it went Before I went trying to change capacitors and there’s 5 here’s a pic
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
