I have the same problem, when you press on the button nothing happens. The only difference is that it use to work on Old Dell D620's running Vista but now they don't work anymore since we've moved to HP 6930's running Vista. If anyone has any idea's to get around this it would be greatly appreciated.
I had same problem with Kodak s1220 scanner. Smart button didn't invoke the oem program in Windows 7 64 bit. It started the windows program which wasn't as slick as the oem. I un-installed and re-installed programs in all kinds of orders to no avail. The updates didn't address the issue. I finally started digging in the various folders in the update package and found a directory called "Button app" it had a install setup program and a file called "killKSS". After that it worked! Sweet. Now if I can only charge kodak for my time.
Check out this link. It's where I found my update. It definitely has I series scanners listed. If the folder I mentioned earlier isn't in your update maybe I can send the folder to you to try. Let me know.
http://graphics.kodak.com/docimaging/US/...
It was located in the update which was a zip file that had been extracted.
SOURCE: I have a Kodak i1210 scanner, I brought it used,
I have the exact site where you can download the free touch driver:
http://graphics.kodak.com/DocImaging/US/en/Products/Document_Scanners/Desktop/i1210_Scanner/Support/Drivers_And_Downloads/i1200_Plus_Series_Scanner_Smart_Touch_Drivers/index.htm
Just click the link, then you will be directed to the site, once you get there scroll down to the bottom you will see the download Button, click it, it is for free download for Installing the scanner drivers from the link on the bottom of this page
will install the latest Smart Touch drivers for the i1200 Plus Series
Scanners.
Hope this will definitely work for you.
Please let me know if you get it for free.
I've looked around and haven't been able to locate the folder or the update you speak of? Where did you get the update? Also I'm using an i-series scanner and not an s-series, I wonder if it makes a difference in the software?
I had tried that site before, there are two packages, one that's roughly 14MB and the other 51MB. I've installed both packages and I can't find that folder? Where is it located, under C:\Program Files\Kodak?
Thanks for your Help!
