Manufacturers put their name on lots of other peoples stats. Honeywell has a very good help line and an online service. Need to know whose thermostat white- rogers, Or honeywell Or Model number
https://www.youtube.com/watch?v=dkMCdjJdKRs
The E1 or E2 error code is an Auto-Stop Protection Error, indicating an issue detected by a sensor. This error code will require service. The E3 error code displays when an Abnormal Operation Protection Error has occurred, and activates to protect the unit from damage. This error code will require service. https://www.lg.com/us/support/help-library/e1-e2-or-e3-error-code-CT10000014-1340721215523 In this case, you need to drain water and remove the laundry. Then, run the rinse mode to clean the drum. Next, start the technique to make sure that the OC error has disappeared. If the washing machine is not correctly connected to the drain hose, OE, OF, E3 will appear on display.
https://all-errors.com/samsung-washing-machine-error-code-e3/
AC
The E1 or E2 error code is an Auto-Stop Protection Error, indicating an issue detected by a sensor. This error code will require service. The E3 error code displays when an Abnormal Operation Protection Error has occurred, and activates to protect the unit from damage. This error code will require service.Dec 20, 2018 https://www.lg.com/us/support/help-library/e1-e2-or-e3-error-code-CT10000014-1340721215523
support-us.samsung.com/.../pop_troubleshooting_fr... Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08 Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Error Code: E1 Loss of communication between the Single Zone LCD thermostat and the mod-ule board. LCD will cycle between E1 and the previous mode setting. System will shut down. E2 Open circuit or out of range Indoor Temperature Sensor. Heating and cooling operation will be locked out. Fan operation can continue to operate. E3 Shorted Indoor Temperature Sensor. Heating and cooling operation will be locked out. Fan operation can continue to operate. E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat Pump operation will be locked out. Air Conditioner, Fan and Furnace operation can continue to operate. E5 Open circuit or out of range Freeze Sensor. Air conditioner mode of operation will be locked out. Furnace, heat strip, heat pump and fan mode of operation can continue to operate but displays the last temperature set-poi
Hello there I have written a list of codes that should cover your problem nd give you some idea what to check ok
E1 or E2
Thermistor
Failure
The dryer
will not operate if the exhaust temperature drops below
18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error
code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the
error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
E3
Touchpad or
Software mismatch
Flashes when
there is a touchpad or software
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
