It is a 1982 4hp outboard evinrude what is the starting sequence there is a slide lever on the top then underneath to the left I think that is the choke /fuel on off switch then to the right there is an other control is this the mixture control if so what is the correct way to start it.?? I have not got any manual on this engine
SOURCE: what is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
SOURCE: need a manual for a evinrude 4hp outboard
Try this link and see if you can find what you are looking for. Hope this helped and best wishes.
http://www.marineengine.com/parts/parts.php
