Hi. You need to be more specific. Printed paged are OK or it's just when making copies . If both copies and prints are bad . The problem can be in the printer section but if only copies are bad the problem is in the scanning section .
If you can make copies but you cannot scan documents to folder or email then I would consult your resident IT person. If you are not able to make copies but the machine prints then you have a bad scan lamp. If you are not able to make copies or print and the scan lamp is as bright as can be then your laser unit is shot.
First be sure that your printer cartridge is Ok (not blocked). Did the Canon feed the paper? Can you print, or there is a problem with scanner section pifonski
Maybe your pdf is protected by print password, in this case, you have to use the pdf password remover to remove the print permission.Here is tutorial on how to remove it on windows: http://www.pdfpasswordremover-mac.com/pdf-password-remover.html
You-Tube video "BNhsIalgVfk" placeholder (do not delete)
Hi there, iR1600 are special machine that needs a little bit more care.
First, clean the laser unit and optics ( beneath copy glass too ). Then use some polisher and polish the developing cylinder and clean/replace developer cylinder blade.
I am sorry but some companies do not have Mac drivers for the older devices. You can try downloading the SWITCH ( not sure of the correct name) program that lets you run a make shift ( simulation) windows on your Mac and that may be the way to print to this device.
