I formatted my sony flash media player.Currently it displays the boot message walkman then it turns off. How will I fix this..?
the model is nwd-b103f.Any softwares for repair???
Hello and Welcome to FixYa!
I will suggest to reinstall the firmware (the operational software) on your MP3 Player.
Follow the following procedure to upgrade firmware:
You are done. I hope this works for you.
* If other Digital Music Players are connected to the computer, disconnect all of them from the computer.
Windows XP/Windows 2000 users: Simply open the downloaded file by double clicking it.
Source: Sony Official Website
Kindly rate me if i was helpful.
Regards,
Waqar
No ! no softwares are required just take it to a sony authorised service center and get the battery changed
First, you go to DEVICE MANAGER. Under PORTABLE DEVICE,
there is your WALKMAN. Right click on the WALKMAN. Choose UPDATE DRIVER
SOFTWARE. Then, LOCATE AND INSTALL DRIVER SOFTWARE MANUALLY. Then, choose LET
ME PICK OF DEVICE DRIVERS ON MY COMPUTER. Currently you are using MTP USB
DEVICE...so, now choose USB MASS STORAGE DEVICE. Then, click next. Once u have
done all this, format your walkman. Your walkman should be fixed. :)
I had the same problem with you before, and i tried this. My
walkman has working like usual, now. I'm using Windows 7. So, best of luck!
P/S : U also can change back your driver to MTP once your
walkman had fixed by doing the same step. ^^
