Compaq Evo Workstation W6000 PC Desktop Logo
Anonymous Posted on Aug 20, 2009
Looking for windows vista drivers for compa workstation evo w6000
Lee Hodgson
Level 3:
  • Compaq Master 4,810 Answers
  • Posted on Aug 20, 2009
Lee Hodgson
Compaq Master
Level 3:
Answers
4810
Questions
Helped
1781631
Points
15941
Sorry the Evo Workstation W6000 does not support Vista.
You can however try and find Vista drivers for certain components like your audio for example, if it's Realtek AC audio you may be able to source a driver for that. If the graphics is Intel you may be able to source a driver for that but you need to know which manufacturer made the different components so you can source them individually, it takes time but some people succeed.
If you don't know who made the internal components like audio and video then your better off reinstalling XP, get all the drivers for that, go into device manager and jot down all the manufacturers and type of the different components like display and audio, then you can try and source Vista drivers for them.
Good luck.
1helpful
Uatx motherboard in mini atx case
Probably however if you upgrade the motherboard you will have to upgrade the CPU, and the memory, possibly the hard drive if the old board is IDE and the new is sata. Also you would have to upgrade the power supply if it's so old it may not have sata power connectors.
Dear sirs, I would like to upgrade the cpu`s of my Compaq Evo W6000 PC with the Motherboard Model 06D0h. Please let me know what are the strongest cpu`s I could use. Many thanks Murat
I suggest this to you.
Intel Xeon Processor, 1.4 GHz/100.0K
Intel Xeon Processor, 1.5 GHz/100.0K
Intel Xeon Processor, 1.7 GHz/100.0K
Intel Xeon Processor, 2.0 GHz/100.0K, L3
Intel Xeon Processor, 2.2 GHz
Intel Xeon Processor, 2.6 GHz/400
Processor, 1.8 GHz, 603FCPGA
Processor, 2.0 GHz, 603FCPGA
Processor, 2.2 GHz, 603FCPGA
Processor, PRST, 2.4 GHz/400, INT 261668-004 284645-001 source: ftp://ftp.compaq.com/pub/supportinformation/technotes/evo_w6000_workstation_rev6_us.pdf
Is a Gigabyte GV-N59X128D graphics card compatible with the w6000
The Gigabyte GV-N59X128D is an AGP8X card and the motherboard of the PC does support AGP so yes both of them are compatible.
The network adapter in my compaq evo w6000 has gone bad according to at&t. spent an hour an the phone with them...all settings are correct, the LAN says it is up and functioning. I can connect to the...
OMG a 16 year old desktop gee, why own this?
came with windows 2000, then 2001 XP. both Dead OS. bad news that. why post at all lacking what OS your run of the many./
your ATT guy probably never seen anything this old
for sure 1st tier helpers.... "a look by him and OMG what is that thing)
what adapter, of the many?
wifi, 3/5G wireless, or Ethernet wired.
it came new with zero wireless anything.
wired only and slow. 100GB only.
we cant guess network unless a tiny hint added like wifi or?
looks like it came new with a relic NIC eithernet port slow.
there, and modern OS do not run now on that chip
im reading your relic service manual now for you.
the RJ45 on the rear , is Ethernet (wired)
you connect a CAT5/6 cable to that and to your router.
and it just works, that is if the Intel driver is loaded.
Integrated Intel PRO/100+ Management Adapter
How can i reset my compaq evo w6000
Hi, insert the cd that came with it, boot the system with it and follow step by step instruction on repairing and formatting the hard disk or get a windows operating system and perform the same.
Reguest for Compaq Evo W6000 Windows vista drivers
By installing Windows Vista the above mentioned drivers will get detected automatically. As Vista has got plenty of drivers in it. After installing Vista check the device manager and let me know the entries which has yellow marks on them so that I can search the driver for you.
1helpful
Maximum IDE HDD capacity for Compaq evo W6000
yes, just had to be partitioned and formatted for the system.
1helpful
2answers
Compaq Evo W600 IDE HDD Installation Problem
REFORMAT THE HARD DRIVE LONG FORMAT NOT QUICK AND NTFS....THEN ALL SHOULD BE WELL AT REBOOT.RICHARDM69
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
