Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
