How do i clean the blades
how do i remove the fan cover for cleaning
how do i remove the back for cleaning
Motor runs blades turn slowly
I am certainly not an expert on this field; yet i have done this my self and this is what i did:
MOst fans have clips.
check where the from and back pieces attach. there should be several clips there remove them and voila.
if not there possibly check the centre pice of fan this may have a screw that holds front and back pieces together as well.
Pllease note you will also have to remove the legs from the side of fan as well. if the pic is the same one you have
Hope this helps
Roty:)
Never argue with an idiot
They bring you down to their level
Then they pummel you with experience
SOURCE: How do you clean Patton Floor fan?
The grill is in two halves with the back half attached to the motor. The front with the round patton insignia removes easily by applying leverage with a screwdriver. There are eight spots (at least on mine) where it clips. Be sure to remove any disposable plastic fastener holding the two halves together. Its pretty easy.
SOURCE: Fan blades are filthy!
put motor oil to the midst of your fan blade may there are lots of rust inside then wait 5 hours then try to pull again patiently...
SOURCE: Cleaning
After you have the front cover off, you'll see the center screw cap that holds the blade on. Simply unscrew it...BUT, typically you would unscrew a nut by turning it counter-clockwise. Instead, this cap is threaded the opposite way, so you have to twist it off turning clockwise.
After you have the screw cap off the blade slips off and you'll see that the back has a screw cap also (or at least my model does). It has regular threads so it screws off counter-clockwise and then you can slip the back off.
Its very easily done and requires no tools to do. Hope that helps you....Dan.
