Garden Logo
J
Julie Addyman Posted on Jul 05, 2019
Why on level 1161 it has only 14 goes when it should be 21
What is the laser classification of Staples mouse B250?
maybe this will help:
  • Class I laser product means any laser product that does not permit human access during the operation to levels of laser radiation in excess of the accessible emission limits as defined in Table I of 21 CFR Subchapter J Part 1040.10. Class I levels of laser radiation are not considered to be hazardous.
  • Class II laser product means any laser product that permits human access during operation to levels of visible laser radiation in excess of the accessible emission limits contained in Table II-A of 21 CFR Subchapter J Part 1040.10, but does not permit human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table II of 21 CFR Subchapter J Part 1040.10. Class II levels of laser radiation are considered to be a chronic viewing hazard.
  • Class IIIa laser product means any laser product that permits human access during operation to levels of visible laser radiation in excess of the accessible emission limits contained in Table II of 21 CFR Subchapter J Part 1040.10, but does not permit human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table III-A of 21 CFR Subchapter J Part 1040.10. Class IIIa levels of laser radiation are considered to be, depending upon the irradiance, either an acute intrabeam viewing hazard or chronic viewing hazard, and an acute viewing hazard if viewed directly with optical instruments.
  • Class IIIb laser product means any laser product that permits human access during operation to levels of laser radiation in excess of the accessible emission limits of Table III-A, but does not permit human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table III-B of 21 CFR Subchapter J Part 1040.10. Class IIIb levels of laser radiation are considered to be an acute hazard to the skin and eyes from direct radiation. Class IIIb laser products may have removable panels that, when displaced, permit access to levels of laser radiation ranging from Class II to Class IV.
  • Class IV laser product means any laser that permits human access during operation to levels of laser radiation in excess of the accessible emission limits contained in Table III-B of 21 CFR Subchapter J Part 1040.10. Class IV levels of laser radiation are considered to be an acute hazard to the skin and eyes from direct and scattered radiation. Class IV laser products may have removable panels that, when displaced, permit access to levels of laser radiation ranging from Class II to Class IV.
  • 0helpful
    2answers
    Cannot advance to next level.
    Which game? Is there a 21st level to this game?
    Blinking AC button of Honda Civic 2003
    HEATING AND AIR CONDITIONING
    HONDA CIVIC 2001 - 2005
    How to retrieve DTC:
    The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
    1.Turn the blower fan OFF.
    2.Press and hold the recirculation control switch and the rear window defogger switch down.
    3.Turn the ignition switch ON (ll).
    4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
    - If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
    - If the system is ok, the recirculation indicator stays off.
    DTC TROUBLESHOOTING INDEX
    DTC (Recirculation indication blinks) Detection Item Page
    7An open in the air mix control motor circuit.21 - 16
    8A short in the air mix control motor circuit.21 - 16
    9A problem in the air mix control linkage, door, or motor.21 - 17
    10An open or short in the mode control motor circuit.21 - 18
    11A problem in the mode control linkage, doors, or motor.21 -19
    12A problem in the blower motor circuit.21 - 20
    13A problem in the EEPROM in the heater control panel;
    (THE CONTROL PANEL MUST BE REPLACED).21 - 38
    14An open in the evaporator temperature sensor circuit.21 - 23
    15A short in the evaporator temperature sensor circuit.21 - 24
    - In case of multiple problems, the recirculation indicator will indicate only the DTC with the least number of blinks.
    - In case of an intermittent failure, the heater control panel will store the DTC until the ignition is turned off.
    I need an instruction book for the pasta boat
    For elbow, bowtie, ziti, rotini, and penee
    1 serving -1/2cup -water level at #1
    2 servings -1 cup -water level at #1
    3 servings - 1 1/2cups - water level 2
    4 servings - 2 cups - water level at 4
    6 servings - 3 cups - water level at 6
    8 servings - 4 cups - water level at 8
    cook times based on serving size ( serving size - minutes)
    1 - 17
    2 - 18
    3 - 21
    4 - 23
    6 - 25
    8 - 27
    Stir macaroni once halfway through cooking for al dente; for softer pasta, cook several minutes longer.
    and just because I couldn't find this online no matter how hard I tried:
    For spaghetti, linguine, angel hair and fettuccini
    1 serving - 1/2 the handle - water level 1
    2 servings- 1 full handle - water level 2
    3 servings- 1 1/2 handles - water level 3
    4 servings- 2 full handles - water level 4
    6 servings- 3 full handles - water level 6
    8 servings- 4 full handles - water level 8
    cook time servings/minutes
    spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
    thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
    angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17
    10helpful
    2answers
    Pasta boat manual
    MicrowavePasta Boat InstructionsFor elbow, bowtie, ziti, rotini, and penne
    1 serving -1/2cup -water levelat #1
    cook times based on serving ( serving - minutes)
    1 - 17
    2 - 18
    3 - 21
    4 - 23
    6 - 25
    8 - 27
    Stir macaroni once halfway through cooking for al dente; for softer pasta, cookseveral minutes longer.
    For spaghetti, linguine, angel hair andfettuccini
    Cook Time: servings/minutes
    angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17)
    Drives fine on level terrain start up a slight grade it stops,engage brakes nothing tractor goes backwards will not stop.
    When you go up a grade do you smell the belt burning (rubber burning smell) when it starts going backwards on you. It could be that the drive belt is not tight enough.
    1helpful
    2answers
    ACURA tL 2000
    Did you check trans fluid level??
    I have RT2280. Audio levels used to be 1-50, now
    Sounds to me as if someone may have gotten into the menu to adjust the individual levels of each loudspeaker and cranked some of them way up. As to why the "main" volume level goes from1-20 now as apposed to 1-50, you got me there...
    Is there a reset button or equivalent on the remote or the unit? Try that. Try unplugging the unit for 15 minutes...
    Here's the owner's manual:
    http://support.radioshack.com/support_audio/doc66/66651.pdf
    See page 21 for advanced volume control functions...
    Top Garden Experts
    Jay Finke
    Jay Finke
    john h
