even with the RV perfectly level the same problem occurs.norcold model #6162 rv fridge
Are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
I am using gas and the temp control is all the way on coolest setting
