Question about Sharp Televison & Video
47in Sharp Flat screen Won't turn on ..The Indicator light come on and blinks over and over..LC52LE830U..Model 106842583//
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Check the power supply voltages. Replace board if they are low or missing.
Posted on Jul 12, 2019
SOURCE:
  • 33 Answers
SOURCE: Sharp LC-37SB24U will not turn on
I can tell you 100% that the problem that you are having will be a service issue. I can also tell you that your limited warranty covers in home service from sharp. Give them a call 1-87-SEE AQUOS(the advantage line that will get you through much quicker). or the 1-800-BE-SHARP and let them set you up for service, sharp will take care of that as long as the purchase date of your tv was within 1 year. If you dont want to go through that, I suggest taking the tv back to where you got it from if they will accept it because unfortunately, this problem can ONLY be resolved through service. good luck & keep me posted
Posted on Feb 19, 2009
ginko
  • 19396 Answers
SOURCE: Blue blinking light
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
dsacco86
  • 1077 Answers
SOURCE: sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Posted on Jul 31, 2009
  • 9 Answers
SOURCE: my sharp aquos flat screen
Call Sharp at 1-800-237-4277. There are firmware upgrades that this lcd needs to resolve issues. Good luck!
Posted on Oct 07, 2009
  • 8 Answers
SOURCE: magnavox 37" flat screen model no.37mf23id/37
Yes, he means 2200 microfarret (called uf from here on out). Another important concern when buying a replacement is the voltage. You need to get something that is at least 25v. I recommend a 35v or better. Another notable point is that this may not always fix the problem. As with mine, there was also a 1200uf (microfarret) 35v capacitor that was blown. You can tell this because they bulge at the top. I have both of these caps (2200uf 35v and 1200uf 35v) on order and they will be here tomorrow. If I do not post back here then they fixed the issue for me. I suspect that this will resolve the problem. Look for bulges on top of the caps. This is an indication that they are blown. Most all of you experiancing these symptoms will see the 2200uf cap bulging but you may also see others bulging too. If you do then you need to replace those too. No electrolitic capacitor should be bulging at the top so if its bulging its bad, and if its bad then your tv will definitely not work. Have fun.
Posted on Oct 13, 2009
Sharp LC52LE830U where can i get mounting screw size
Contact the authorized dealer. They can help you.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 30, 2014 | Sharp Aquos Televison & Video
Won't turn on. Light flashes and makes a whirring noise
do you mean the light indicator in the front panel was blinking?. how many time does it blinks and can you give us more info about your tv, the brand as will as the model no. it was located at the back of your tv.so we can give much better solution to the problem.
Nov 17, 2012 | Televison & Video
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Keep always blinking the green lights indicator ones i plug the power cord. no video, no raster on the screen.
The green lights on a Sharp television indicate a problem. The number of blinks is a code. The television has gone into a coma in order to protect itself. You can force this television on by doing this. Unplug the television. Hold down the vol+ and channel down button on the television and while holding them down still plug the television in. This is a temporary way to view the television but the problem will get worse if not repaired. Should the television power on this way unplug it when you want to turn it off without pressing the power button at all.
Dec 09, 2010 | Sharp LC-32SB24U 32 in. LCD TV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp lc-22sv6u won,t power on. no green light.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Televison & Video Logo
23 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
