Garden Logo
A
Anonymous Posted on Jul 04, 2019
Karcher wv2 window vac won't charge. It is plugged in correctly& connected to mains.
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 08, 2018
SOURCE: No suction on my Karcher window wv2 vac
Check the hoses for clogs due carpet fibers.
My karcher window vac charges but does not switch on.
Could be a defective switch, or it is locked because a threshold is reached, like reservoir is full.
But check while it is charging, because the manual says:
Oct 01, 2014 • Garden
2helpful
Karcher wv50 spare on off switch
If you contact one of the Karcher Centers ( details are on Karcher.co.uk website) they may be able to help.
regards Gary
2answers
My karcher window vac does not seem to charge?
Have you tried to take it all apart just a small bit of rubbish will stop it from working.
2helpful
2answers
Why wont my karcher window vac switch on even after a full charge any ideas ?
Take it apart and see what is stopping it (the motor) from turning .
9helpful
Can't switch Karcher window vac off
I had the same problem and I let the battery run down to stop it cycling on and off. My husband investigated it and found that there is a fault with the on board battery charge sensing circuit. (when the charge is about 10 to 15 % remaining the onboard ic controller cycles the unit on and off, irrespective of the switch. He checked it by cutting wires to the switch and it still cycled off and on so the switch was not faulty.
He put it all back together and said to charge it before it gets too low. If it cycles on and off it probably needs a re charge at that point.
Unfortunately there is no battery level indicator on the tool and nothing to suggest in the manual of what may happen when battery is flattening.
I am taking this up with Karcher as I only used it three times so far and it it was not a cheap gadget. Hope this helps
3helpful
2answers
Cordless vac won't hold a charge
Like all batteries after a while they go bad/will not hold a charge. especially the kind that is always plugged in/always charging, like electric shavers, cordless vac and so on.
get a new battery
thanks for rating
Jan 14, 2008 • Vacuums
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
