I found the manual for this model weed eater, according to the manual the mixture... and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be mixed at a Ratio of 40:1 ...." and I quote once more from the manual "Helpful Tip. To obtain correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps, If you like I can send the manual via email if you need it.
Most gas weed eaters use 2-cycle engines. For the Homelite 2-cycle engine trimmers, use a 50:1 ratio of gasoline to the Homelite lubricant. (For 1 gallon of gas, add 2.6 oz of the oil.)
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
40:1 = 3.2 oz of 2 stroke oil for every gallon of gas
Link to manual is below
http://www.weedeater.com/ddoc/WEEO/WEEO2009_USen/WEEO2009_USen_TE475-952711797_545186833.pdf
Check 1. Compression 2. Gas/oil mix 3. Air filter 4. Spark at spark plug. This is just the beginning of troubleshooting a 2 stroke. They develop fuel line problems and carburetor problems and magneto air-gap problems. Critical though is the oil/gas fuel mix that is used. It needs to be fresh and mixed at the correct ratio. Check all these things that you can and post back.
taking head off to replace cable
