After I print a document on my Lexmark 5150 printer, the document does not delete from the printer queue and I cannot print another document w/o restarting the computer every time. I have deleted and re-installed the printer and even changed USB ports but the problem still persists. Any suggestions?
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the problem is fixed.
4. Double click the printer icon in the lower-right
corner of your taskbar to examine your print job queue and browse to View ->
Refresh.
Try to print again to verify that the problem is fixed.
