Samsung HTP-1200 System Logo
Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System sometimes just will not play dvds. disc
System sometimes just will not play dvds. disc spins then stops, spins thens stops. turning the unit on the off a few times sometimes resolves the problem. this problem is intermittant, and i have no idea what may cause this. Is there anywhere i can take it to get it look at
Francisco Mauricio G
Level 3:
Genius:
  • Samsung Master 1,551 Answers
  • Posted on Aug 19, 2009
Samsung Master
Level 3:
Genius:
Answers
1551
Questions
Helped
524986
Points
4192
Clean the laser lens first
2answers
Panasonic BD35 won't play blu ray discs, but will play dvds
You may have come close to what the issue is---Blu Ray for several design reasons is much more critical than DVD---seen a lot with this issue----either a dirty or a failing optical pickup in the unit---I know as when first started seeing it in our shop changed a few and since under warranty found the answer--optical unit was the problem---shortly after that they started just exchanging the cheaper units.
2answers
My bose lifestyle 48 system suddenly stopped playing new DVDs...is there a problem with the head..I bought it only in 2008
is the discs just spinning and then stopping when you put them in the drive?
there may be a chance that the lens might just needs cleaned. suggest a dvd lens cleaner but on the down side there is a strong possibility it may be a faulty lens. dvd players aren't built to last.
always clean the dvd player from dust and keep in an open space.
2helpful
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
2helpful
NEW DVD DRIVE AS MINE DOES NOT WANT TO PLAY NO DVDS NO MORE, IT SPINS THEN STOPS THAN SPINS THEN STOPS THEN SAYS NO DICS!!! CLEANED MAGID EYE BUT STILL DONT WORK
run ur pc in safe mode and insert dvd disc and then use this around 2min and then start ur window normally and ur dvd drive working
System won't play dvds ( says it a bad disc when it's not)
get the free upgrade CD from BOSE and it will solve most of the problems when the program is loaded.
1helpful
Disc Error when I try to play a dvd LG DP781
Sounds like either a dirty or weak laser/lens. Pls try cleaning with a CD disc cleaner or manually using cotton buds (if the eye is accessible).
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
2answers
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
3answers
Bad Disc
First determine where the problem lies. This can be done by analyzing what is happening. Is the disc spinning. Is it spinning erratically? If the disc is not spinning, the spin motor is probably defective. But sometimes you can be fooled, if the laser does not detect information of the disc, it will not issue a start spin motor command. If you can get the unit to work with the door open by defeating the switches,(Do not under any circumstances look directly into the laser)If you see the laser then the spin motor is bad, In either case the unit is is probably cheaper to replace than to repair. Scrivitron
Check disc
Change your DVD player
This system stopped playing DVD with a very slight use
1. An unplayable disc is inserted. 2. The Rating level is set, Cancel the Rating function or change the rating level. good luck!
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
