SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Testimonial: "Haven't tried the suggested solution but makes sense."
SOURCE: 1994 Buick Skylark, 138,000 mi.,V-6, auto trans.
one thing ive warned my friends to never do and that is to never have your trans flushed cause you may have new fluids but what about the trans filter its old and iots there for that reason to keep dirt and metal; shavings from the bands so try having your oil and filter in the transmission replaced , pull your trans dip stick and on a white piece of paper put a drop of trans oil that you have in your trans at that very moment it should be redish pink but if its brown and smells really bad then the problem is in the oil and filter . change it before u have to replace the whole trans
SOURCE: 2002 zx9r engine dies intermitantly when cluth is pulled in or when put in gear
Check the sidestand is up.
SOURCE: boom creeping down on case c28 excavator
You can download factory case manuals from here Case IH
