Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
Posted on Aug 19, 2009
Ipod is disabled connect to itunes
Help me? my ipod touch is disabled connect to itunes because passcode screen when i connect to itunes my ipod device can't show in itunes,and i try to restore press Power and hold Home plug to computer i can't find USB Driver for i pod....my windows is xp sp2!!!! i try to reinstal windows xp and itunes 8 but can't work.....please help my ipod touch 8 GB
[email protected]
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1029
Points
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
985
Points
It says ipod is disabled, connect to itunes
qbashir_alam
Level 1:
New Friend:
  • Posted on Nov 01, 2012
qbashir_alam
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
985
Points
Itouch disabled
When your iPod Touch displays a message telling you to connect it to iTunes, it may be in recovery mode, or have been disconnected in the middle of an update.
To get rid of the screen, you must reset your device. If in passcode mode, an iPod Touch must be manually unlocked or fully restored to get back to the home screen.Forcing a Reboot
When your iPod Touch is stuck on a screen that is instructing you to connect with iTunes, a normal restart will probably not work, as the hard drive has become frozen.
You can still, however force the iPod to reboot using a process called resetting.
To reset an iPod Touch, hold down the "Sleep/Wake" and "Home" buttons at the same time until an Apple logo appears, indicating that the device is rebooting.
When an iPod Touch reboots, it always goes back to the lock screen. Passcode mode will still be enabled.
Unlocking With the Passcode
If you know the passcode for your iPod Touch, slide the "Slide to Unlock" arrow and then enter your code on the next screen.
Upon entering your password, you will be directed to the device's home screen. If you enter the wrong password too many times, it will become disabled temporarily.
The iPod Touch can also be set to erase all content after 10 incorrect passcode attempts if you previously enabled this feature, don't attempt more than 9 entries.
Unlocking Without Passcode If you have forgotten the passcode to your iPod Touch, the only way to unlock the device is by restoring it.
Restoring an iPod Touch returns it to the factory settings, meaning that any settings, applications or music you added to the iPod are removed.
Once the device is restored, you can re-add your downloads and other information using the backup copies in your computer iTunes program.
The passcode setting will be disabled unless you manually enable it again.
Consideration
If you don't have a backup of your music and applications in iTunes on your computer, you can also download another copy from the iTunes Store or App Store on your device after a restore.
Any photos that are deleted during restore, however, will be lost forever if a backup does not exist.
Always back up your information via sync on a regular basis to avoid this problem.
9c93a00208
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data.
Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so.
However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled.
To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player.
Launch iTunes if it does not automatically open.
Select your iPod touch under the devices list, and click the "Summary" tab in iTunes.
Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes.
Click "Restore" when prompted, after the back up saves. After restoring, click "Ok."
Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen.
Click the "Continue" button to restore your iPod touch.
iOS: Forgotten passcode or device disabled after entering wrong passcode
http://support.apple.com/kb/ht1212
iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
1helpful
My Ipod touch is disabled Please HELP ME
If it was locked and you donot know the password then the only thing you can do is restore it using dfu mode hold both power and home button until it turns off and restart and show you to connect to iTunes2_bing.gif. Then restore it. Let me know what happened.
3helpful
My ipod-touch is disabled, please read the details
restore it to factory settings using itunes
15helpful
3answers
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Help!
Looks like you need to reset your ipod to factory defaults, they are still a really buggy products. Sorry. =(
1helpful
8GB iPod Touch Disabled
Hey,
read this page i posted
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Let me know if you need anything else.
Thanks,
Ekse
IPod Touch Passcode problem!
hold home for five seconds then while holding home put in your usb connecter while its connected to the computer and it will be put in recovery mode from there restore it and put your music back in!
1helpful
2answers
Ipod is disabled
Hold sleep and home button for ten secs (or until you see recovery mode screen) then connect to itunes
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
