Hi PUK code is called as PERSONNAL UNBLOCKING KEY. Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause. To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider. While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code DONOT enter the PUK code several times wrongly,It will block your sim card permanently. This PUK code is FREE. You no need to pay any sum to get the PUK code Thank You.
Usually the PUK code is needed when you have entered an incorrect pin number more than three times. The phone then locks and until you enter the PUK code, you can't use it. You will need to phone your service provider, using another phone, or if they have a shop handy you could call in there and ask for their help. If you can phone them, they will usually tell you straight away.
Hi, Pin codes are not found on phones , there are on Sim cards, except you are talking about Unlocking code?. When you exceed the pin code trial, cause you just have three chances to try the pin number, it will now ask for Puk number.
PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software. Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone.
Hope you are not talking about Pin code and not lock code.
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Donot try PUK code many times or else your sim will be blocked and you will need a new sim. Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. Go to the nearest service outlet of your service provider they can also help you. There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Well you could try inputting random codes until the phones asks you for a PUK code, if it doesn't ask for one already.
Then you'll need to call your carrier's help number, and ask the representative for a PUK code. (You'll need paper and a writing utensil handy)
When you enter the codes you were given, it should reset the security code, and you'll be able to use the phone normally.
ok if you need your puk code you will have to call your carrier (optus,vodaphone ect) and tell them u need your puk they will ask a few security questions then they will provide the puk enter it into your mobile and then it will say add new pin do that and it will say repeat if nesscery write down the puk just in case of this again
By The Sounds Of It Its Asking For The PUK Code To Retrive That Code Ring Your Service Provider And they Wll Give You The Code Just Ring And Ask For Your PUK Code
Hope This Helps And Please If You Have The Time Please Rate Me That Would Be Great
