Kenmore 5 cu. ft. / 142 liter Chest Freezer 11511 Logo
Anonymous Posted on Aug 19, 2009
The front surface of the chest freezer is
The front surface of the Kenmore chest freezer (5 cu feet) is "very hot" and the sides of it are OK. I wonder if it is safe to use and if there's any way to resolve the problem. please advise.
  • Anonymous Aug 19, 2009
    thanks for the useful reply. Let say 1 is cool and 10 is getting burn. I would say that the front surface of my freezer is about 7 and the sides of it is about 2. I have to add that I just got this freezer yesterday and I tested it for 5-10 minutes. Then, I found that the front surface is "getting hot" and I therefore unplug it immediately. I am not sure if it is normal or the heat would die down with time. Please advise again. Thanks.
Anonymous
Level 2:
Novelist:
  • Expert 116 Answers
  • Posted on Aug 19, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
116
Questions
0
Helped
55614
Points
364
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Testimonial: "Thanks for your useful advice."
  • Anonymous Aug 20, 2009
    Hi, that temperature (7) is o/k, (5) would of be a little to hot, plug/connect your freezer, let it work/run for an hour, before you put/pack your produce, temperature of front of freezer, will drop , longer it work/run. that's normal, that's the way it's design. so enjoy your freezer and plug em up. Good luck.
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Cubic feet for Frigidaire Chest Freezer MFC13M4FW3
Good Morning, thank you for your question! This particular unit is a 12-13 cubic foot freezer. If you have further questions, please do not hesitate to reconnect.
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
The front surface of the chest freezer is pretty hot.
the condenser lines are between the walls of the frzr and if it has a fan to cool the compressor down and it is stalled is the reason the walls are so hot and no it will not cool down over time if new is a flaw in making of this unit take it back or if older only the side should be getting warm not hot then if older be cautious of this no repair can be done on these type of unit they are between foam filled walls....
Chest freezer - hose adaptor?
That would depend on the size of the freezer. If it's a compact 5-7 cubic feet, then its not necessarily needed, but if it is a large freezer I would recommend buying the hose adapter. The basic function for the hose adapter is draining the water after defrosting the freezer.
So if it's a large freezer that will not be moved, then YES by all means, you need the adapter.
1helpful
Lost contents of freezer
hi . thanks for the question .you can use a spray called ozium you can find it on line it will do the trick thanks the appliance doc
1helpful
2answers
Kenmore Chest Freezer
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
1helpful
External Surfaces of Fridge/Freezer are hot
That is normal, refrigerators work by removing the heat from the storage area, thus making it cold. This heat has to go somewhere. Most of it is blown out the back but some escapes through the sides of the fridge.
15helpful
2answers
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
