Can't load the audio driver on acer 4720z notebook of acer, with windows home edition of xp loaded on it. driver fails to load of realtek company.
Is there any other way to solve the audio problem? after i install win xp sp3 in my acer aspire 5550,i get stuck in installing audio driver.i have download the driver from many website even in acer.com, but still cant solve it..please give me some idea..
How can i install the sound to my acer 4720z laptop with windos xp program
Here's how I got Acer realtek hi def audio to work on my 4720z;
force install of microsoft uaa bus driver from xp install disk, or search MS. 'cos of the Intel/Realtek audio chip, vista recognize and adjust but xp do not. Once that bus driver is installed, you can run Acer XP Real tek driver and do the install.
note; during the xp find, might request you install bluetooth, CIR, and HDA modem.
Hello all. Just want to share my experience with acer aspire 4720z. My sound driver's problem was solved. You may want to read this article: http://doktertomi.com/2008/04/10/installing-audio-driver-on-acer-aspire-4720z/
I have found this useful article : Installing Audio Driver on Acer aspire 4720z
Now my acer aspire enable to play music!
The article has been moved to my other website. You can read it here: SUMBER ARTIKEL INI DARI WEBSITE ANTARNISTI.COM :http://www.antarnisti.com/2008/04/instal...
I CAN FIX THIS........
After installing the appropriate driver, it won't work untill you do the following.
Here is what you do..........go and download from realtek's website the driver for high definition audio from realtek. then.....after the appropriate driver is installed, restart the computer.
Then go to your device manager (right click on "my computer" - go down to properties, click on the "hardware" TAB, click on "Device Manager, go down to System devices and click on the little plus sign in there.
There should be an asterisk or an exlamation mark by something called "PCI Device."
Double click on it, and when it asks if you want to re-install the drivers, DO IT.
Restart the computer after you click on re-install drivers.
and VOI LA.........the sound card works.
Hi...after breaking my head for 2 days i was able to solve the issue by trial and error ... go to device manager and uninstall realtek high definition driver... then go to add or remove programs in the control panel and uninstall realtek high definition audio driver software .. restart the system and try to install the audio driver form the given CD... it should work...
if not uninstall bluetooth device also and try again...
Audio device on high definition audio bus
I WANT PUT 1 TERA IN MY NOTEBOOK...ASPIRE 4720...
Reformat your hard drive
Reinstall your windows XP
Now here is the magic: open your Acer Resource DVD and install the Realtek Audio Driver before all others drivers ( even before the chipset driver ).
Hi Friends,
Problem with Acer Aspire Notebook Or Laptops? Just visit the sites..
For any Software problem you can visit a link by just Click Here .
For any Hardware problem with this Notebook you can Click Here
This site have all XP drivers for Aspire 4720 and Travelmate 4720
http://komku.blogspot.com/2008/01/windows-xp-and-aspire-4720-travelmate.html
This worked on 420z for me and xp sp3;
install microsoft uaa bus driver from xp install.
I had to load blutooth driver and hda (agere) modem and cir (winbond) driver as well, BUT after install ms uaa bus it finally asked for hi def audio. Hooray!!!
go to acer realtek audio xp driver, install, reboot.
I think this driver's not work in xp sp2. just go here: http://www.workinthewebsite.com
Sdfs sdf sf sadf sf sdf
Visit the manufactors website and find the updated file needed for the sound, You will find it needs a update from microsoft a KB file is missing or needed.Also try microsoft update.Hope this helps
sometime if we cannot find the right driver in the official website, we can find the answers here, http://www.audio-driver.net/
SOURCE: acer aspire 4720z audio driver for widows xp home edition sp2
Have you gone to the acer site? and second question I too have an acer and I got rid of Vista is this what you did or did the computer come installed with xp. If it did make sure you have the Microsoft hdd coded driver installed. It is available by googling "hdd audio driver" it will send you to microsoft to download. Also make sure you have completely deleted the previous software before loading the new one they will conflict and load on top of each other. Hope this helped..Take care.. Be mucho blessed..Mark
probably because it is still not the correct driver you are installing
try: http://soulpass.com/2007/11/10/installing-windows-xp-professional-sp2-on-acer-aspire-5315-2153-laptop/
i know some of that specific laptop and most as their brand. go to their website and try redownloading the audiodriver for that laptop. i have more information so please email me if you have any more questions, please email me at [email protected]
am not able to find the sound drivers for xp for my laptop acer aspire 4720z
Acer Aspire 4720Z PC Notebook
Fail to load high definition audio driver
Atheros AR5007 EG wireless network did not work on XP SP2
i hv treid to solve this problem by going in device management but it cant update or unintall the driver plz help
For Acer Aspire 4720z, First Changed the HARD DISK type as IDE, then installed XP.
Audio driver for mixer is not working
have the same problem ..realtek is not installing ... i am not finding any solution for it ... please help if any one has found out how to solve
same problem,cant able to install realrek drivers on my 4720z
hi i have the same proplem
give me driver
hi
I have same problem.
Anyone can give advise.
Installed realt.e seems evrything is ok but no saund.
PCI device can not be detected, and because of which sound and modem are missing
Acer aspire 4720Z with Windows XP P with SP2. audio cannot be installed
acer 4720z windwos xp cant install network, sound driver
i cant get sound drivers
acer3000
I have the ausio problem in my acer 4720Z and the audio is not being downloaded it is showing failure notice.
Dear sir,.
my laptops are not installing all drivers (windows xp) please sir help me. my laptop model no :- compaq v3777tu.
i'm not able to install audio driver on acer aspire 4702z notebook.....
can help me please...............
when i instal vista in my Acer Aspire 4720z audio can, but when i changed my Windows to be XP2 Why the Audio Cant. i have try to download some audio driver Realtek R_166, R_190 and etc but still FAILURE...............
I can't instal driver audio
i am enable to install audio drivers on window xp in my acer 4720z
i have a problem installing my acer aspire 4720z sound driver on windows vista OS.
My notebook Acer Aspire 47207Z same problem.Sound drive Realtex can't Suport with XP SP2.if you can help me Send a email
thak's.
i install windows xp but audio driver i not workinf plz help me to fix this my problem
When starting windows, volume is low and the same problem while playing any audio or video.
No sound.
realtek driver is not getting installed frm acer dvd of drivers
can't load the audio driver on acer 4720z notebook of acer, with
realtek company
i just try to download driver from net.but no use.
I try install driver audio for aspire 7420z but the high definition not available in cd driver so that cant install it and no sound
same
i have Acer Aspire 4720z, im not able to install Realtek audio drivers from driver CD.
I have the same problem
i have the same problem of audio driver installing .
sambit sabyasachi
same proble audio divers
I AM NOT ABLE TO LOAD AUDIO DRIVERS
realtek driver is not accepted by my laptop.showing failure.
i too have the problem in installing the audio driver of acer 4702 Z laptop. kindly help me in this issue.
with regards
rajesh
i want acer aspire 4720z audio drivers for windows xp
looking acer aspire audio driverfor window xp
no audio when i'm in chat room,help me to fix it
How do I install an audio device on my Acer Aspire Desktop
I just realised that my laptop does not produce sound
my laptop lacks drivers
i have same problem and i want sound driver in my acer laptop
my sound does not work.!!!!!!!!!
hi.
i have acer laptop
i format this
but i have not CD for d drivers
so pls help to install sound driver,modem driver and all necessary drivers....
help
can't load realtack audio driver .
i loaded windows xp sp3 and my audio dont work now
there's no sound in my acer 4702z.
hd realtek cant load in my computer, what's wrong?
mufty-taiwan
You know that Acer Aspirce 4720z comes with Vista, so it's drivers is ready to work for vista, but i installed windows xp sp2, and most of drivers didnt' work, so i need those drivers but to work with xp.
Thanx
do no install audio driver on my note book
I need network drivers for Aspire4720z
i need sound driver for acer 4720z windows xp
ican't get sound
when i download audio driver from Acer Driver CD..realtek reflect HD failure error....
so plz arrange the audio driver for me so that i use that in my laptop
no sound devices in my laptop
kljnki
device pci can't istall
ya i too have the same problem
can't install the realtek audio driver
drivers for xp
jnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnnn
Please describe the specifics of your problem below. We'll add your post as a comment to rumit's "acer aspire 4720z audio driver for widows xp home edition sp2" problem
cannot detect bluetooth from pc to handphone
i have problem to find unknown device driver of ascer aspiron 47202z laptop
After Installing the sound driver I can't listen the sound in the Laptop Speaker
I have an acer extensa 5220. I changed my xp dark edition os, and installed an xp pro. All went ok except that it has no sound on windows media player playback. I have downloaded realtek audio driver but and updated the driver but still my sound does not work. please help me solve this problem. thanks
realtek HD audio
Try installing the window again and restart the laptop each time you install drivers
Reinstall the windows as its a common problem faced if you have windowsXP ,and restart the laptop each time you install drivers
