I thought it was my Yamaha pre amp so I bought a new one Output signal from audio interface registers on pre amp but everything else is dead
Hello Dez, indicate the models of your Yamaha that you are commenting, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Dez, indica los modelos de tus Yamaha que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
SOURCE: No HDMI video signal to projector
cheak out put on samsung to set it at 720 hdmi out ect might nee dto use red green blue or s video to see menu
SOURCE: no audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
SOURCE: Avalon 737 Pre Amp Repair (New York City)
If you are not looking for a warranty repair, any shop that handles high end audio repairs should be able to resolve this for you. Before you ship off the pre-amp, verify that it is, in fact, the pre-amp that is defective. The initial stage of the power amp can cause this as well. Try hooking up another pre-amp instead to verify the problem location.
Keep us posted,
Dan
SOURCE: Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
