I visited the p3 International site and this was under common questions asked: The check light keeps coming on. What’s the problem? A: Try cleaning the blades. Make sure they are absolutely dry before turning the unit on. If the check light still comes on, the unit is defective. Give return instructions.I visited the p3 International site and this was under common questions asked: The check light keeps coming on. What’s the problem? A: Try cleaning the blades. Make sure they are absolutely dry before turning the unit on. If the check light still comes on, the unit is defective. Give return instructions.
You can't post conmments that contain an email address.
Re: Ionizeair "check" red light is still on after...
These things are junk. you could also be doing more harm than good to
yourself and the indoor air quality in your home with the amount of
ozone these appliances omit into the air. throw it away
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Filter Replacement Filter Replacement Indicator: Your Defender® is equipped with a Filter Replacement Indicator located on the front panel. Anytime this red indicator flashes, it is recommended that you call your authorized FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops flashing and remains solidly illuminated, it is recommended that you change your filter. To receive full benefit from your Defender® and to extend your warranty, it is strongly recommended that you follow the filter replacement schedule suggested above. Under higher pollution levels, your filters will need to be replaced more frequently. The Filter Replacement Indicator is operated by filter time in use and is controlled by an onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter Replacement Indicator will begin to flash. It will continue to flash until the you reach 12 months of time in use, at which time the Filter Replacement Indicator will stop flashing and remain solidly illuminated. After replacement of your Medi-Filter® Cartridge, you must reset the Filter Replacement Indicator's timer. When the timer has been properly reset, the Filter Replacement Indicator will turn off. Resetting the Filter Replacement Indicator Timer: After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the Filter Replacement Indicator's timer can be reset by performing the following sequence of steps: 1Plug unit into outlet. 2Press power On/Off switch to the On ("I") position. 3Allow unit to start running at low speed. 4PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator starts to blink. 5 Release both the Up and Down arrow buttons. 6 While the Filter Replacement Indicator is still flashing*, again PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator turns off. If the steps above have been performed properly, the Filter Replacement Indicator will turn off and not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again. *Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time. The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above. Note: Under higher pollution levels, your filters will need to be replaced more frequently. Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call 1-440-846-7800 for the Distributor nearest you.
1. Plug unit into outlet.
2. Press power ON/OFF switch to the ON position.
3. Allow unit to start running at low speed.
4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink.
5. Release both the UP and DOWN arrow buttons.
6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
It won't go out by itself.
there is only one other thing that i can think of that might work ifyou haven't done that yet. right above the timer button there is a small pin hole. that is your reset button. you need like a safety pin or something really small to go in that hole. hold it for about 3 seconds. take the pin out and the system should reset back to normal. sometimes when you clean the filters that happens. not every time but sometimes. Now if that doesn't work. i would call the manufacturer again so see if they have any other solutions or if they can send you one more. I do apologize for the inconvenience. I will keep looking for you to see if there is anything else that i can suggest but try that first.
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
