SOURCE: sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: My sharp ar-5316e photocopier displays H4. what should i do
The H4 means "Heat roller low temperature detection"
Basically the fuser is not reaching a specified temp within a specified time frame. There are several causes/posibilities :
Thermistor abnormality
Heater lamp abnormality
Thermostat abnormality
Control Board PWB abnormality
or it is just a one glitch and it can be reset.If re-seting the copier does not work then it could be something physically wrong.
To clear error go into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" (must be in copy mode to start off). enter 14 and start key. Confirm if requested to do so. copier must be restarted when this is done. Do not play around with any other settings in SIM mode.
If error persists then one of the above items is at fault. you could pull out the fuser unit and open it up to check for any dirt/debris buildup around the thermistors/thermostat.
Hope this will help.
SOURCE: CODE L4-02 JUST ILUMINATE ON MY SHARP AR-M 350U PHOTOCOPIER
That code means you have a drum drive motor failure. The drum is the long, cylindrical green-blue tube you'll see when you open the left-side door.
Chances are some paper jammed up inside the drum process unit (that black frame that holds the drum) and it's keeping the drum from turning. Check the drum/process unit and make sure they are clear of any material that could cause a jam.
SOURCE: i have photocopy sharp ar-5516 and when i switch
Perform the following procedure to enter the simulation mode.
"#" key Interrupt key "C" key Interrupt key
press 14 and start key twice.
copier should restart normaly.
If not, then you have problems with the fuser, contact me to tell you what you have to do next.
Regards,
Adi
Testimonial: "thanks a lot it was very helpful"
