Question about Orion STV2763 27" TV
Can I replace a output cord on a orion stv2763
SOURCE:
  • 53 Answers
SOURCE: Orion STV2763 fails to power on after power failure
assuming you have un plugged the set to re set shutdown circuit you might check all zener diode's around power supply pay attention to 9v supply these tend to open after power problems.
Posted on Jun 15, 2006
salt56
  • 373 Answers
SOURCE: dtv ready?
Usually on the back of the set there will be a hookup for digital tuner. To get the converter box before Feb 2009 go to http://www.dtv2009.gov
Posted on Mar 16, 2008
jerryg50
  • 1691 Answers
SOURCE: orion stv2763
You need the original remote to access the menu system in your set. Most all the TV's on the market are like that.
Jerry G.
Posted on Jul 19, 2008
  • 979 Answers
SOURCE: all i want to know is if the Orion stv2763 transmits on a digital
Insufficient information
Posted on Dec 29, 2008
  • 520 Answers
SOURCE: is my Orion STV2763 digital or i believe they say
I'm sorry. The STV2763 is not digital. If you use an antenna, you will need a converter box for this tv. I hope this information helps you.
Posted on Apr 14, 2009
Orion stv2763 weight
Google the model number with specs to see if that information is online or not.
Dec 10, 2012 | Orion STV2763 27" TV
NECESITO EL NUMERO DEL FLY BACK DE ESTE TV
El numero del FLY BACK es 043227021F y es posible que obtener de partstore.com
http://www.partstore.com/Part/Directed+Electronics+Inc/Orion/STV2763/Directed+Electronics+Inc/Orion/043227021F/New.aspx
Feb 09, 2011 | Orion STV2763 27" TV
Is my Orion STV2763 digital or i believe they say does it have a atsc tuner?
Apr 13, 2009 | Orion STV2763 27" TV
Delete "closed captioning"
http://www.newtvremotes.com/Mfrs/Orion/OrionTV/076RODJ020.htm
This may be your only solution
Jan 05, 2009 | Orion STV2763 27" TV
Line across the screen
dry joints on the field output ic is a fairly common problem with these.if a firm slap changes things,a simple resoldering job does the trick.resoldering is usually the cure ir the fault was intermittent.otherwise the ic may need to be replaced.cheap as chips,so to speak.hope this helps,steve.
Nov 05, 2008 | Orion STV2763 27" TV
Orion stv2762
http://www.newtvremotes.com/Mfrs/Generic/ACCord.htm
I serch the web and found this see if one of this is the one
a picture of the back of your tv can help may be I got it.....good luck and rate me
Jan 01, 2008 | Orion STV2763 27" TV
Hooking up Dvd to TV
Buy an RF adapter for 30.00. It takes cable in and dvd and
has one output to tv.When you play DVD's it auto switches!!
Saves alot of good tv's.........T.
Oct 25, 2007 | Orion STV2763 27" TV
Wrong or 3-Digit Channel Numbers
that request is not available...firm-wared chip proprietary from orion
Jun 01, 2007 | Orion STV2763 27" TV
May 31, 2006 | Orion STV2763 27" TV
Orion STV2763 27" TV Logo
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
