Hi Jim, with your Onkio TX NR686, you can select any of the connected audio sources
I sent the user manual link, see page 65 and follow the steps indicated
I hope I can solve your concern
Greetings Franco Dosil
Hola Jim, con su Onkio TX NR686, puede seleccionar cualquiera de las fuentes de audio conectadas
Le env?o el link de manual de usuario, f?jese en la pagina 65 y siga los pasos indicados
Espero pueda solucionar su inquietud
Saludos Franco Dosil
https://www.es.onkyo.com/downloads/3/3/4/1/8/Manual_TX-NR686_En.pdf
https://www.es.onkyo.com/downloads/3/3/4/1/8/Manual_TX-NR686_Es.pdf
https://www.es.onkyo.com/downloads/3/3/4/1/8/Manual_TX-NR686_De.pdf
SOURCE: Zone 2 speakers will play from tuner but not from cd player
I have the denon as well two zones. 5 speakers inside and 2 speakers outside- can you play both zones at once? meaning can i watch tv in the 5 zone area inside. And play my IPOD in the outside speakers at the same time? PLEASE HELP! thx
SOURCE: Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
SOURCE: Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
SOURCE: Zone 2 speakers only work with the tuner - no
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
