You're problemme is the counter shaft seal is leaking....this is the seal right behind the front sprocket....i tough there is also a inner o-ring on that model that you shall have to change...thank you for leaving good feedback.
The sprocket sholdn't contain any oil. Its probably the brakes or your shocks/dampers. It needs to be replaced or seals fixed. Confirm what the fluid is prior to repair.
