Microwave Ovens Logo
m
maryann barzelatto Posted on Jul 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE PVM1870SM3SS microwave oven only counts down the time , no power, the vent opens , nothing else
Dennis
Level 3:
Top Expert:
  • Master 1,057 Answers
  • Posted on Jul 03, 2019
Dennis
Master
Level 3:
Top Expert:
Answers
1057
Questions
Helped
441116
Points
13558
My initial guess is that the thermo fuse is blown. Simple to replace, only need a Phillips screwdriver. Heres a YouTube video describing how to proceed.
https://youtu.be/HV4SJA-_N_c
Model Jvm1330bw002. Why does it do nothing when cooking time is set?
How to fix microwave that counts down but does not heat or ...
? 4:51
https://www.youtube.com/watch?v=PIU1NRpeA_8
Oct 2, 2012 - Uploaded by G-Unit_YouTuber
How to fix frigidaire microwave door sensor relay switch. If your microwave is counting down but will not turn on, this could be one of your problems to test... ... My Ge Jvm1540dm4bb microwave stopped heating & spinning so I opened it .... Microwave Oven Troubleshooting in MINUTES ~ STEP BY STEP ...
1helpful
GE JVM1790 Convection / Microwave Oven has no power except control panel
Seriously, check those door switches again (especially the top one and bottom one). Check them in place with the door both open and closed, and make sure you have continuity in 1 case (door closed) and open circuit in the other case (door open). You probably need to pull off the wire connectors to make sure you are getting an accurate reading.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
PVM1870SM3SS will not power up found burnt THERMO SW-TCO SENSE TEMP
This part is a Cabinet fuse and will stop power to the control panel, works through L1. This open or fails when the microwave cabinet get too hot and it is protecting itself.
So yes to your question.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Have a ge pvm1870sm3ss micro lost power after use open door a couple times came back on did it again after use but now it is total dead can anyone help?
A door switch or two are bad and it took out the main fuse.. Change the door switches and fuse. Get the correct parts and make sure you get the switches in the proper locations and configuration
Clock, timer ,key board work ..but set time and it counts down but nothing goes no turntable or heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101
Microwave panel display works but fan and
See this file.
We're happy to help and appreciate your thoughtful rating.
I have a GE microwave with the message sensor error
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the macimum amount of time. Use Time Cook to heat for more time.
Thanks.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
