SOURCE: assembly instructions
See the other posts about this bassinet. It is going to be recalled soon because it has caused a couple of deaths. Please don't use it!
SOURCE: Instructions
if you go to there website you should be able to read or download the instruction manual
SOURCE: I need assembly instructions for a wilson and fish...
I didn't have my instructions either, but I finally figured it out. I do the top first. I'm 5'2" and I put it up by myself and this works for me. The leg connections are 6&5 with 6 being on the bottom with little holes near the base stand and 5 being on top. Add the corner connectors and side connectors to tops of 5. Out from the corner connectors add your 7's. Out from the side connectors the 10's for the long side and 8's for the short side. For the top corners add 4 then 3(it is that funky looking rod). In the middle connector add the 11& 12(this will be for the long sides).You will connect corner and sides with 1 (make sure to put the sliding connector on the rod with the Y's at the ends. On the top, top add the last rod. I think you'll be able to figure out how the canopy drapes. I hope I've given the right directions for yours. I put mine up yesterday.
SOURCE: I purchased a Wilson & Fisher? 10? x 12? Bay
Call Wilson & Fisher and get the to send you the instruction sheets .
Can do this either by conputer or fax.
