How can i change my message tone on my samsung f480 from the standard tones set on the phone
Instead of changing the ringtone settings, tap the message alert tab (in the top centre of the display).
A set of message alert settings appears . You can change the Message alert type, if you want to, by tapping the panel and choosing the appropriate option.
To change the Message alert tone, press the Message alert tone panel .
In the menu that appears, press Change.
Then choose one of the options Use effect tone (one of Samsung's pre-loaded effects) or Use my alert tone (allowing you to choose from your own sounds) .
In this example, press Use my alert tone.
Press the Sounds option. In a similar way as changing ringtones (above) you now have the choice of choosing from your Music files, Ringtones that are loaded onto the phone, or My voice clips .
In our example, we'll again choose a file from our Music folder.
Press the Music option. A list of suitable MP3 tracks appears.
Tap the one you want in order to highlight it.
Press Options, then tap on the Select menu option to install it as your message alert .
You are now taken back to the Normal profile settings, where the Message alert tone has changed .
To save this change, press Options and then Save .
Alternatively, press Back and you will be asked whether you want to Save? Press Yes
