Question about HP Office Equipment & Supplies
Get fatal error message after installationof
Get fatal error message after installation of printer
    New Friend:
  • 9 Answers
This happens when the installation stops at 96% for pretty long time and then shows fatal error message after installation..what you need to do then is " DO NOT HIT OK ON THE FATAL ERROR MESSAGE BOX"..and then from task manager end the process which says "hpqzsetup"..and then restart your computer..im sure after restarting the computer you will be able to print!
Posted on Jan 31, 2010
    Guru:
  • 1,738 Answers
Make sure that your firewall program is shut down before installing the programs. I have hp program on mine and after I shut down my firewall it went through. Try downloading the latest software from www.hp.com
Posted on Aug 18, 2009
SOURCE:
Error 030 fatal error
ecblank.gif What does "Fatal Error" mean? ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Summary: Printer has displayed a "Fatal Error" message. This simply means a problem has occurred requiring you to take action. It does NOT mean that your printer has "died". ecblank.gif ecblank.gif ecblank.gif ecblank.gif
ecblank.gif ecblank.gif Your printer display or status monitor may read "Fatal Error". This simply means a problem has occurred requiring action to clear.
A "Fatal Error" does not mean your printer will "die". Fatal Error explanations are not usually found in the User's Guide or Handy Reference Guide.
RECOMMENDED NEXT STEP: First, try turning off your printer then turning it back on. If this does not clear the message or remedy the problem, check to see if your printer is on a power strip (or not plugged directly into the wall). For testing purposes, be sure the printer is plugged directly into the wall. Often, the issue is power-related.
Second, if the issue persists after this, write down the message (including the 3-digit error code number) and email us at "support@okidata.com" or call Oki Data Customer Support (1-800-654-3282) for assistance.
NOTE: If you see a series of letters and numbers(scrolling across the display) after the 3-digit error code, be sure to write these down also and report them when call or emailing Customer Support.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 25, 2011 | OKI C5200n Laser Printer
Error message fatal error during
make sure its compatible with computer before installing because you computer need to recognize the printer after you pluged the printer with computer
Oct 14, 2009 | HP Photosmart D7460 Printer
Fatal error when installing HP Officejet 8500, fails at 96%
hi did you get any particular error during the installation that said fatal error 1935 or 1709 or some other message if you get any error message please mention the specific error code and try the step mentioned below
insert the cd in to the computer and then go to computers and right click on the cd icon and open it now you will see a Util folder open it and then open CCC and in CCC you will se some files like uninstall_L2, Uninstall_L3, Uninstall_L4
if you have a HP computer then open uninstall_L3 and continue to clean the printer entries If you do not have a HP computer then open UNINSTALL_L4 and continue
after cleanup restart the computer and then go to c drive >>Program files >>HP and delete the digital imaging folder
now install the printer software once again if you still get a fatal error at 96% then do not click on the ok button of the error screen directly restart the computer and when it restarts go and try to print in will print fine
and still if you have any problem then you can call the HP helpline for free support that is 18004746836 24hrs support
Sep 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Fatal error installation of ProL7590
There are alot of fatal error messages. You need to provide the exact fatal error message.
Here are the basic troubleshooting for that type of error :
1. Turn off your firewall, anti-virus and spyware and then install it
if it will not work
2. Download the software for your printer in the website www.hp.com/support make sure that you are going to download and install the full feature of the software
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Fatal error msi.webreg
hmm..did you run disk clean and defrag, after uninstall?
Jun 16, 2008 | HP DeskJet F380 All-In-One Printer
OKI C5500 Fatal Error 177
From OKI error log:
Lower heater temp state - Low
backup roller thermistor indicates low temp
seek service if turning off/on printer does not solve problem
Apr 15, 2008 | OKI C5500n Printer
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Open Questions:
268 people viewed this question
Clive
Clive
Thomas F. Schneider
