GE oven functional code F1 appear and alarm beeps. Can cancel alarm but it returns after 15 sec. Neither oven nor cooktop are being used when alarm displays. All troubleshooting I have seen says to replace range controller/display unit for this problem. I did and still have problem.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
The new controller I've just installed is the complete controller including keypad. Any other suggestions?
