Sy Somerstein Posted on Jul 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audio sounds muffled - Audio Players & Recorders
Franco Dosil
Level 3:
Top Expert:
  • Audio Player... Master 10,542 Answers
  • Posted on Jul 05, 2019
Franco Dosil
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377268
Points
178965
Hello Sy, indicate the brand, model and type of equipment you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Sy, indica marca, modelo y tipo de equipo del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
1helpful
Why does my Nikon Coolpix L820 when during making a video it will sometimes Muffle my voice during a short video or long video?
The manual says that the stereo microphones are either side at the rear of the flash. Make sure nothing is near them. It also says that it can be affected if the flash is raised. It sounds like a firmware issue, and it is a pity there is no external mic jack socket.
https://www.google.com/search?q=nikon+coolpix+l820+video+muffled+audio
Dec 30, 2022 • Cameras
1helpful
Audio seems weak...how to increase volume
this is gotta be the largest complaint I hear from folks when they get a new flat screen , its not loud enough or the sound sounds muffled
flat screens are flat ! so theres no good way for mfg to put the speakers facing forward so sound has to hit the wall behind it first then gets directed forward to you ! (low/muffled)
sound bars help with this , but for true rich sound , id go with a video receiver amp combo , some of these even have built in dvd players , and arrange its speakers in a forward facing direction
Sound gets muffled at certain frequencies. Please Help!
I think that rather than the mixer, that your front speakers may have a limiter built into the high frequncey amp. You may be asking them to do more that they are capable of.
Do these speakers work better with an amp? I am playing them now and they sound muffled using a regular shelf system
No models given, so a guess is what you get.
If your shelf system is not producing sufficient clean audio power you'll get distortion, which can kill a speaker faster than excessive clean power. Muffling is something else altogether. Are the tweeters working?
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
2helpful
Sound is muffled toshiba 57h81
There is a switch at the back of the set for audio, it is in the wrong position.
Muffled sound
plug it in properly and replace the internal speaker- simple
1helpful
Sound is muffled ..
I just fixed mine with the same problem. The was a switch on the back by the audio jacks. Move the switch to the opposite position. Hope its the same problem.
Audio Problems With MP3
First thing you wanna do is to try another set of headphones. If it still sounds muffled then theres a fault in the audio output section and these things are non user serviceable. Your gonna need to send back to the manufacturer. Good Luck
 Grubhead
Grubhead
SmartAviator
SmartAviator
